Question about Crosley CR248 Turntable
The CD holder won't open.
The CD holder to our Crosley turntable/CD burner won't open. You can hear the motor try to open. The display says there's a blank CD inside.
  • Anonymous Nov 08, 2008
Mine did the same thing. I found a broken belt. Now I am looking for a new one. Hope this helped.
Bob
Posted on Oct 03, 2008
My Crosley CR49-TA won't revolve. It turns on, and
Most turntables are belt driven. Suggest you take a look inside but remember to unplug the deck first. Usually it's a simple case of slipping the belt back on.
Apr 26, 2013 | Audio Players & Recorders
Crosley turntable problem
HAVE YOU CHECK FOR ANY SPRING ATTACHED, THAT COULD BE LOOSE.??
Mar 22, 2008 | Crosley 4-in-1 Entertainer CD Shelf System
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
Belt came off on my crosley cr49 record player
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Aug 29, 2009 | Crosley CR49-TW Tweed Traveler Turntable...
Crosley Radio CR246 CD door will not open
Try checking these:
- the CD door motor rubber drive belt (if there is one), it could be either loosened or broken, if so, it needs to be replaced
- the door open/closed sensor switches (contacts), they could be oxydized or damaged, they are located somewhere under the CD tray, possibly at the front end of the unit (depends on brand and model), you need to clean these with some fine sandpaper
It could be something else like the door motor driver IC, the power supply for the motor, a bad capacitor in the motor drive section, a loose connection or a broken wire somewhere, but hopefully, it's just a bad rubber belt or a dirty contact.
regards
3rq8 (Triarcuate)
Aug 08, 2009 | Crosley CR248 Turntable
Crosley CR66 turntable not turning, belt is fine - motor?
frozen motor maybe or blown interal fusesmaybe,try manualy spinig platter to try an maybe free it up
Aug 07, 2009 | Crosley CR248 Turntable
Crosley CR49 Turntable Speed Problem
Do you know how to make a measurement? open your equipment, use your voltmeter to see how much voltage run the motor and then compare with the voltage who is written in the motor. If the voltage which your have read is in the range of motor voltage +- 10% is ok, of no, that voltage must be more than that correct that problem.
If the voltage is the range of motor voltage the replace the motor.
Thank you.
Tell me if this helped you
Mar 03, 2008 | Crosley CR49-TW Tweed Traveler Turntable...
CROSLEY SONGWRITER CD BURNER CR246
Here is the entire manual that comes with the unit. www.crosleyradio.com/Manuals/CR246_Manual.pdf
Jan 06, 2008 | Crosley CR248 Turntable
Crosley CR248 Turntable Logo
427 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
