Question about Kenmore 43142 Front Load Washer
Oversudsing I must have put an extra capful of detergent into the load because there are suds I can't get rid of. I've redone the load in plain water and tried an extra rinse, but still sudsy. What should I do?
    Genius:
  • 1,122 Answers
DON'T PUT ANY CLOTHS IN WASHER,LET IT FILL UP WITH WATER THEN TURN IT OFF ,LET IT SIT OVERNIGHT TO LET IT DILUTE IT SOAP,THEN TURN BACK ON TO FINISH CYCLE-MIKE
Posted on Sep 20, 2008
  • MIKE major Sep 20, 2008
    thanks for nothing(thanks for trying)!!!!!!!!!!!!!!!!!!!!!
When my Maytag bravos washer starts to wash cycle it stops with an F 51 code. it dose it every time it agates
Cause: suds. The wrong detergent or the wrong amount of detergent, makes the motor overheat.
Why? In my opinion when suds are detected the program needs to make them go away for fear the clothes won't be clean. So the program makes the motor do extra work to try and fix the problem. The poor washer motor gets worked to death because the water ain't right. This washer is designed to work with a small amount of water. Only a tiny amount of soap is needed to do the job. Put a cup of detergent in there and the machine is gonna constantly run way past time to be done just to get rid of the detergent. This causes the machine to overwork the motor and destroy the rotor position sensor.
Feb 04, 2011 | Maytag Bravos MTW6600T Top Load Washer
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Tub leaks, with a partially filled tub (2.5 inches measured from the lowest point over the pump assembly.) Promblem occured after the washer was idle for 3 weeks. Have just replaced the main water inlet...
I am assuming leaking when it is running, not sitting idle. Leaking from the door? Fill and run unit for 1 minute with no detergent. Open door. Are suds present? Suds turn into water when they drop to the floor. Suds can flow over the lip of the tub and drip to the floor. Oversudsing, Sometimes old detergent breakdown. Rinse aid dispenser leaking will cause oversudsing. Combination of all in one products will cause many problems. If suds are present after running unit a minute, pour a cup of cooking oil in unit. Run and fill it a few times until suds are gone. Possible most common cause is dispenser latch grommet.
Oct 15, 2010 | Maytag MDB7100AWB Dishwasher
Code is OE
The washer only uses 1 gallon of water to wash clothes. You go putting in more than a teaspoon of detergent in there then you is gonna get a sud lock situation. You must use low sudsing HE stuff very sparringly. The washer will detect oversudsing and dump extra cold water in there to try and resolve it. An OE error means it took longer than 10 minutes to pump out the water. 2 things these washers hate is too much detergent and clogged filter/pump.
Jun 11, 2010 | LG WM1812C Front Load Washer
Towell cycle taking longer than before
The washer only uses a tiny amount of water to do them clothes. If you use more than a teaspoon of HE low sudsing detergent that washer will detect suds and take extra steps to rid the suds. This causes motor problems.
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Flashing F-21 and SD wont finish a load
Your washer is designed to use a TINY amount of water. This conserves water and takes less energy to heat the water. Since it is so little water used any amount above a teaspoonful of detergent will reek havoc with the delicate controls on the machine. F21 Long drain Possible cause: Clogged filter, clogged/failed pump.82f0c42.jpg Sud= Suds lock detergent overdose. Too much detergent, the wrong stuff, added to the wrong compartment, you gotta use HE soap and you gotta use the correct amount. You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water a9be475.jpg
used in HE machines, it is important
to use an HE detergent (low sudsing)
which is specially formulated to work
best under these conditions. The two
most important considerations
of a front loading washer are suds
control and soil concentration.
First, the tumbling action in an
HE machine generates
more suds than a top loader.
Tumbling the clothes in and out of the
water breaks the water surface
causing air to be trapped in the solution,
creating suds or foam. Multiple problems
can occur from oversudsing, such as
flooding from suds overflowing out of
the machine, formation of a suds cushion
during the tumbling action which reduces
mechanical energy,and “suds lock” which prevents
the machine from effectively spinning out the
water. In the situation of suds lock, the
machine trys to FIX the foaming problema by
stopping the cycle momentarily to allow
the suds to dissipate and then adding cold
water. This routine the machine goes
through to correct for over-sudsing results
in loss of energy and water savings and
can significantly lengthen the cycle time
(sometimes by as much as 2x). HE detergents
prevent over-sudsing and allow for
better rinsing of suds. HE detergent matters in
soil management also. Though HE washers
use about 1/3 of the water of a
top loader, the concentration of soil in the
load is much higher due to the larger
loads. To handle the higher amount of
soil, many HE detergents are specially
formulated with soil suspending ingredients
to prevent soil from re-depositing
onto clothes. Only use detergent with HE marked on it.
Use the correct amount.
The technical data sheet along with that
pesky clogged pump is located behind the
toe kick panel; remove the screws under the
bottom front edge of the washer. Tip the appliance
back to get to them screws. With the screws
removed, the panel will comes down and off.
Jun 02, 2010 | Kenmore Washing Machines
Whirlpool dryer error code
Your TECH SHEETS mention "Sud" If too much detergent was used. Why? You get that computer thinking suds is in there and the machine is gonna go into a tailspin. Because of the low amount of water
most important considerations of a front loading washer are sudscontrol and soil concentration.
First, the tumbling action in an HE machine generates
more suds than a top loader. Tumbling the clothes in and out of the water breaks the water surface
machine tys to FIX the foaming poroblema by
prevent over-sudsing and allow for better rinsing of suds. HE detergent matters in soil management also. Though HE washersuse about 1/3 of the water of a
onto clothes. Only use detergent with HE marked on it. Use the correct amount.
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
4. Check/clean drain pump filter of foreign objects.ec9f016.jpg
5. Plug in washer or reconnect power.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle. Your tech sheet will be behind the bottom panel and will resemble THIS Suds is on page 6
Jun 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite quiet pak 4 ''suds'' error
I also gots suds error and then "F"?
my clothes were soaked....i can't get the machine to drain now????
Nov 17, 2008 | Kenmore Elite 45986 Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Suds Suds Suds
The SUDS fault indicator is caused by using too much detergent, or the wrong type of detergent. The Kenmore Elite front loaders were designed to use HE type detergent only. When the washers first came out, manufacturers originally made the claim that you could use regular detergent if you used less of it. The manufacturers later retracted that claim because there were a lot of problems with over-sudsing. If you are not using HE detergent, you need to be. In the mean time run your machine with no load with hot water to clear the drum and drain lines of any soap residue. You may have to do this a couple of times to clear the problem. I hope this helps.
Mar 31, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore 43142 Front Load Washer Logo
82 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
