Question about Sunbeam Heritage 2346 Stand Mixer
I have a Sumbeam Mixmaster Legacy Edition S Model #2346. It was purchased 1 year ago and hasn't been used very much. The problem is when I needed to empty the mixing bowl contents into the cake pan, I could not remove the mixing bowl from the mixer because the release button would not free the mixer to tilt back. I thought well my hands must be too weak, so I called my husband to do try. The big strong guy that he is couldn't get it to release either. Needless to say, he held the entire unit (stand and bowl) upside down while I scraped the contents into the cake pan. The cake it great, but now I still have an empty, dirty mixing bowl that I can't remove from the stand. Please help!!!
  • jbscott Jan 24, 2009
    The same thing just happened to us. There are no exposed screws, so we can't take it apart, as one solution suggested. We too have a dirty bowl and beaters that can't be released.
SOURCE: Sunbeam Mixmaster Heritage series
I hope this helps. I found on mine that the rear screw on the "neck" had become slighty loosecousing the release to not fully disingage. I had to remove the dome shaped cap in the middle of the speed control knob, pops off fairly easy, to gain access to the nut to tighten it. Hard part was trying to hold the screw head still while I used a small screw driver and small hammer to tap the nut tight, very limited space between the "neck" and motor body.
btsctn
Posted on Oct 22, 2008
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
  • 2976 Answers
SOURCE: have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Posted on Jan 08, 2009
SOURCE: I have a
There should be a small lever on the base in front of and below the bowl. It will move to 2 positions. It sounds like you have it set for the small bowl but are using the large bowl. Press down on the lever and move it to the other side. If I'm right, that should correct the problem.
Posted on Dec 14, 2009
  • 2841 Answers
SOURCE: My Sunbeam Heritage MixMaster mixer just stopped
If it is plugged into a circuit protected by a GFCI breaker, which it should be if it is a kitchen circuit, reset the breaker. If you know for sure there is power at the receptacle you have it plugged into, then the power cord is bad or you have an internal mixer problem. You will have to pay someone to repair it or take the mixer apart yourself and find out what is wrong. Before paying someone be sure and get an estimate as to the cost of the repair. In some cases you are better off buying an new mixer as the repair costs will exceed to price of a new one.
Posted on Dec 18, 2009
My Sunbeam mixmaster junior model-jc is smelling when it runs
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Jun 17, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam stand mixer won't tilt back down
I'm in the middle of a bake sale. Not a good time to send back. Also, I think you meant a free Upgrade at no additional cost...
Dec 14, 2012 | Sunbeam 2346 Heritage MixMaster Series...
My Sunbeam mixmaster bowl won't turn, how can I fix this?
I believe that this particular model is supposed to have the bowl mix separately. I have removed the black piece from the bottom of the larger bowl in order to allow manual spinning. If I am able to figure out how to fix the bowl spinner I will make another post.
Mar 06, 2011 | Sunbeam 2346 Heritage MixMaster Series...
Vintage Sunbeam Mixmaster MXG makes a strange noise and has a burning smell when operating. Is there anyway I can fix this?
the motor is burning out at the coil you can send it into a electric motor re winder but it could be expensive look them up in your local directory
Jul 04, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster jammed, will not tilt back
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
Dec 28, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Heritage 2346 Stand Mixer Logo
151 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
