Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire affinity not draining
Washer turned off, and is still full of water. We removed the laundry in hopes of draining the water out. When you turn the cycle knob, the washer lights come on and then it makes noise till you shut it off. It is a rattling buzz noise. About a week ago we had washed a bathroom carpet and had to remove the lint filter and clean it. But it has run fine since then. Any ideas?
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
Posted on Sep 26, 2008
We did get the problem fixed. We had missed part of the mess that the rug had left and the motor became to dry to spin. Therefore, it was starting to burn out. My Dad came over and pushed his finger up in to finish cleaning the clog out and then jump started the motor by spinning it manually with his finger a couple of times to re-lubricate. Then it started spinning and is now working fine. Thanks Dad!
I keep receiving an "ER70" on my affinity washer. What does this mean?
Hello rdketo - Typically error code E70 indicates that the water temperatures are wrong. Often this is caused due to the hoses are wrongly connected to the valves. Check the hoses and make sure they are located on the correct faucet and valve. Confirm that there aren't any restrictions or kinks in the drain hose as well. If issue persists, it will be advisable to contact an experienced appliance repair tech to assist further.
Mar 18, 2013 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire Affinity Front Load Washer wont drain.
If your pump had something in it, it wouldn't have had to clog it, but rather just stopped the internal spinning. My coworker removed a dollar bill from his water pump, and it fixed the problem he was having (same as you've described) and the water pump worked well after it was re-installed.
Worst case scenario, you reinstall it and it doesn't drain and you spend 40 or 50 bucks online for the part. I would reinstall and see if it works. I'd bet on it.
Nov 14, 2012 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire affinity washer front-end loader will not start. All hoses are fine, electrical is working fine, all doors are closed. I push start button and PAU flashes, That normal click or locking...
You may need to check the drain pump for anything that could obstruct the flow of water,or stop the impellar wheel from turning.if there is standing water in the unit you can use a wet dry shop vac to drain the water out by attatching it to the end of the drain hose.if you remove any of the hoses from the drain pump ther will still be some water that comes out.
Make sure to also check the boot that is coming from the bottom of the tub and make sure that the coin trap is not clogged.
The front panel has to be removed in order to get to the drain pump.I hope this helps good luck will be looking for any furher questions.
Oct 07, 2011 | Frigidaire Affinity ATF7000E Front Load...
I have an affinity washer and dryer. The last loand did not complete its cycle. It is partially full of water, but not enough to seap out. Itmakes a buzzing sound and will not spin. It is not the type of...
It sounds like the drain pump has stopped. If it still has water in it and you turn it on (in the spin only cycle) the drain pump should be running and you sould be hearing the water drain. The washer will not spin until the water is out. Depending on how handy you are determines whether you can access the drain pump and remove the obstrustion. There is also a trap to catch debries from going into the pump. This could be plugged, but normally you don't hear a buzz. You hear the drain pump working but no water going out. Good luck
Apr 23, 2011 | Frigidaire Affinity ATF7000E Front Load...
How do I access the drain pump on a Frigidaire Affinity front loading washer?
If you cant access it from the front You will have to tilt the machine back as far as safely possible to access the bottom of the machine. Locate the drain pump which will be at the bottom font or back corner and remove the hose that connects the pump to the tub, you will need to have a basin ready to catch any water. You most likely have a sock or something stuck. Hope this helps
Mar 01, 2011 | Frigidaire Affinity ATF7000E Front Load...
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
How do you get to the filter on the water pump on
Hi There
i have some stuff for you to read to help you out on your problem. Let me how it goes and hope this helps you out.
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washer won't spin
Check to see if the strainer before the pump is partially clogged.
Sep 11, 2009 | Frigidaire Affinity ATF7000E Front Load...
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
691 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
