Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore model 59502990 25 qf side by side refrigerator
My refrigerator will make a click noise like it is trying to turn on when I plug it in. The fan comes on, but not the compressor. Is there a relay that I can replace that may fix the problem?
  • 943 Answers
Hi thanks for the question yes there is order a relay by model # and install it should be ok thanks the appliance doc
Posted on Sep 27, 2008
KENMORE MODEL 106.53532300 SIDE BY SIDE WILL NOT FREEZE OR COOL. FANS RUN, BUT A CLICKING NOISE INSTEAD OF COMPRESSOR RUNNING, COMPRESSOR IS VERY HOT. WHAT SHOULD WE DO?
its most likly the start run relay . this plugs onto the side of the compressor and changes it from start to run . these models seem to have this problem in this age range call sears you can get a relay put it on your self not terribly expensive
Jul 04, 2011 | Refrigerators
I have a Kenmore model 363-9550160. It is making a loud "slamming sound" like a clutch trying to engage. It seems like it happens everytime that refrigerator compressor might be turning on to keep the...
that does not sound good and to save you a service call unplug the refrigerator and wait 5 minutes while waiting remove the cover on back covering the compressor condenser and fan us a flash light and make sure if it is your fan motor or compressor making the noise. You may need someone to plug it in as you look for the exact location. Anytime you unplug wait 5 minutes or more to allow the Freon pressure to equalize or the compressor will not start. Tell me what you find, Sea Breeze
Jan 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
Evaporator fan noise. How do I access the evaporator fan motor to replace it?
Turn off the refrigerator. Remove the freezer shelving and bins. Remove the screws holding the rear panel inside the freezer. Repair or replace the fan motor.
You may also have to remove bin supports from the side wall to get the panel out depending upon your model. The model number posted is incomplete.
Sep 06, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore model 57029 side-by-side refrigerator not working
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 12, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Nothing runs but Adaptive Defrost Control clicks twice
ARE YOU SURE IS NOT IN THE BACK THE CLICKING NOISE ,THE RELAY TENDS TO BURNED ,,IS BY THE COMPRESSOR.
Dec 08, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
437 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
