Want a solution to my laptop
The laptop just shut down without any command.
if it shutting down it does so swiftly without any prompts.
it does not happen for a specific interval
  • runawaybell Oct 07, 2008
    ive got the same problem,my laptop gets really hot and shuts down, i rang acer and they told me to format , that i may have software problem, ive formatted and im still having the same problem, some one told me to change the settings to make the fan work all the time but im not sure how to do that and dont know if thats good for my laptop
    Novelist:
  • 188 Answers
Most of the time if a laptop is just shutting down without any press of a button or command, it is overheating and shutting off to protect the processor from damage. This thermal protection is normal, what is not normal is the reason for overheating.
make sure that you are not blocking the airflow that cools the laptop. check for dust or other obstructions to airflow. ( look for vents on the bottom, or sides of the laptop ).
Posted on Sep 28, 2008
  • 174 Answers
Please check the power management option for your laptop
Posted on Sep 21, 2008
Why does my computer automatically shut itself down on the same day each week.
There are a couple possibilities...first, when you say shut down, do you mean that it restarts, or it actually shuts completely off? Windows update will auto-run weekly and restart the system if necessary. Otherwise, I'd suspect something with your antivirus scanner settings.
Jan 10, 2015 | Computers & Internet
I want to factory restore my Compaq Presario V5000 and I can't find the advanced settings to do this what do I do if it doesn't have an F11 option?
THis is from the HP tech chat thing, and it seems to be working. I did method 2 and browsed to the file:
_________________
1. Click Start 2. Click Shutdown 3. The "Shut Down Windows" dialog box will be displayed 4. Select "Shut Down" from the me 5.
Start the system again. 6. When the Red Compaq logo appears press F8 repeatedly until prompted with the "Windows Startup
Menu" 7. Select option 6 (Safemode Command Prompt) by pressing the down arrow key until Safe Mode Command Prompt is
highlighted 8. Press Enter 9. At the C:\ prompt type D: and press Enter 10.At the D:\ prompt type CD CPQS and press Enter
11.At the D:\CPQS prompt type XQR press Enter
Method 2:
1. Click Start 2. Click Run 3. In the "Open" box type C:\CPQS\QUICKSR\FRESTORE.EXE Performing these steps should resolve this
issue.
Aug 15, 2013 | HP Compaq Presario V5000Z Notebook
Shuts down
Are you running xp or Windows 7?
Xp you need to boot into safemode with command prompt
then type:
fixboot
Once it has done that, then type chkdsk /r /f
If your windows 7 you wiull need the disk that came with your laptop, and you can go into either system restore, or chkdsk from there.
Also if you cant get system restore going but can get to the command prompt then type - rstrui.exe
This will bring the rollback wizard
Mar 29, 2013 | Computers & Internet
Get out of safe mode
if you cant turn it of try shutting it down from command prompt
press windows key+r t
when the run box apears type CMD and press enter
type the following command without quotes "shutdown -s" then press enter and it should shut the computer down, if your computer goes back into safe mode when rebooting turn it off then back on and keep pressing the F8 key until a dialog with text comes up, use your arrow keys and navigate down to the last known good configuration box and hit enter it should work
Dec 17, 2012 | HP Compaq 6735s Notebook
Zzy6913@yahoo.com i havwe a new compaq presario laptop 1800 model number a18xl390 and its locked up !!!! how do you unlock this model of laptop ?? can a nyone help thanks the wiz
Locked up screen?? Shut down with button, pull the battery. After five or ten minutes reinstall the battery, Push start button. Screen will say window shut down unexpectedly and ask for start command. Start in safe mode and prompts should come up about your problem and ask you to send a report to microsoft. Do that and follow the prompts. I hope that helps.
Jul 14, 2011 | Computers & Internet
My Acer Aspire 5810TG does not shut down on battery. No problem on AC
Until you can locate the underlying cause of the problem (could be mechanical, or your particular battery power configuration settings), you can try this:
Open up a command prompt window (Start Menu > Accessories > System; or, Start Menu > Click "Run" > Type cmd in the box and press enter)
Once the command prompt session has opened, type "shutdown -s" (without the quotation marks) and press enter.
You should see a box pop up warning that shut down will occur in 30 seconds. After the countdown completes, your computer should begin the shutdown routine. This command works for restarting the computer as well, just change "-s" to "-r"
Jun 01, 2011 | Acer Aspire 1642ZWLMi Notebook
SONY VGN CS215J Shut down by itself
just start the laptop in safe mode with command prompt and run chkdsk /r/f command
how to go to safe mode with command propmt just press F8 KEY when you switch it on.
Sep 10, 2009 | Sony VAIO VGN-CS220J/W Notebook
Dell XPS M1530 trouble shutting down
Try this, just to see if the shutdown actually works.
Open a command prompt and enter the following:
shutdown -s -t 05
-s is to shutdown, -t 05 is a 5 second countdown.  Let me know if it actually shuts down.
Feb 02, 2009 | Dell XPS M1530 Notebook
Hibernate
try this
1. Click Start , type command in the Start Search box, right-click Command Prompt in the Programs list, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue
2.At the command prompt, type powercfg /hibernate on.
Oct 07, 2008 | Compaq Presario R3000Z Notebook
Command Prompt shut down my computer
had the same problem and found an exact solution here...
might as well try it on yours
http://www.techykid.com/virus/auto-shutdown-virus.html
thanks
Apr 08, 2008 | Computers & Internet
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
