I have a compaq presario and when i turn the computer on it says compaq and in the bottom left hand corner it says hit esc to enter boot setup
    Scholar:
  • 32 Answers
This sounds like it does not boot into the Operating System. The boot setup is actually a program that is stored on a Chip inside your motherboard. The program is called CMOS setup and contains all of the options such as power saving, boot order, processor temperature/speed, etc. which can be adjusted by the user. If this is all that it shows, then it means that the computer has not accessed the hard drive yet, it is still reading from that program which is on the motherboard. This chip is what has all of the settings required to start up your system, once it recognizes the hard drive it turns over the start up to the hard drive in order to load the operating system. It may not be recognizing the hard drive. You can enter the CMOS setup and in there is an option where you can see if it recognizes any installed hard drives (unfortunately, the CMOS programs vary for different motherboards, so it is hard for me to know what this option is called, but if you look around you can find it pretty simply). If it does not recognize the hard drive, a cable may be loose. Open the comptuer and make sure all Hard drive cables (usually flat and wide and grey) are connected, along with the power connector.
Note:
If it is a newer computer it may be that the cables attached to the hard drive are really skinny (they may be colored red or yellow and be about the size of a phone cable).
If it is just that your computer has no operating system installed then you should be able to insert a CD (such as XP or Vista) and install an operating system (or use a recovery disk, if you have one that was made for your computer).
I hope this helps. Please let me know if I can be of any further assistance.
Posted on Sep 20, 2008
What keys do I press to get the CMOS setup screen on a Compaq Presario 5222?
Try F2 or F8 or F9. Shouls tell you just before the splash screen comes up ...
Jan 28, 2012 | Compaq Presario 5222 PC Desktop
What button do i hit at start up to reformat the hard drive on a compaq presario 700
Hi purple7558
did you mean format the hard disk and then install the operating system.?
press F10 to enter the bios setup, then set the boot sequence to cd rom first.
insert your windows cd into the cd rom.
save settings and restart. after the computer restarts it will detect that you enter cd then press enter.
the next process is the usual kind of format and install your operating system.
thanks&regards
Jan 10, 2011 | Compaq Presario 700 470024-192 Notebook
My laptop Preasario cq61 has the black screen problem, when it starts it shows the first screen fine ( the one where you can hit ESC to enter the bios) after that it goes black and in the top left corner...
http://h10032.www1.hp.com/ctg/Manual/c01141784.pdf
OK download that service manual, follow the troubleshooting procedures and you will sort your problem out in now time, i have a hunch, that your HDD, is faulty... and may need replacement. Anyway Download and use that manual, it's a generic one.. but will still work for you.
Apr 11, 2010 | Compaq Presario Notebook
Hello i have a compaq presario 5000 when i turn
This is a compicated problem. First when it boots enter setup by pressing the F10. Once you are in set up reset all settings to default. Save changes and exit CMOS. If that does not help the situation have someone make you a boot disk, reenter setup and put the floppy as the first boot drive and then CDrom. Insert the boot disk, follow the instructions to boot. Once you are up and running try to roll back the computer to the last recovery point that worked. If that does not work you may need to see a local repair tech.
Feb 04, 2010 | Compaq Presario 5000 PC Desktop
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Presario sr1200nx
need help email me drummernick2002@aol.com live help thx nick
bad boot will take sum work
May 19, 2008 | HP Compaq Presario SR1200NX (PN211AAR) PC...
Compaq Presario V2000 boot up problem
i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
Nov 24, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
David Payne
David Payne
