Question about Maytag MMV4205 Microwave Oven
Magnetron and diode
2 days after my 1 year warranty was up, my microwave went out. It was $288 when we bought it and will cost $318 to fix. Is this problem inherent with Maytag? I would like to try another one, but, I would need a 3 year extended warranty this time. This is a very classy model as long as it in warranty. Thanks! John
  • johnke4 Sep 21, 2008
    Dear Guru,
    I think I responded in a wrong area of this website. I had a repairman out and he said the magnetron would be $135, including the diode, and the labor would be $165, because it is a difficult job. With tax , the bill would be $318. I definitely am not handy when it comes to electronics!!
    I certainly appreciate you trying to help. I was very encouraged to hear that you have had the same model for 6 years. I think I will try another one of the same. I hope this didn't jinx you.
    Thanks,
    John
  • 5,911 Answers
Common? No. but, sometimes things like this happen. Its called "Murphy's Law". Its funny how these applainces seem to know when the warranty expires. I have owned the same Maytag microwave for 6 years now and never had a problem with it (I've probably just jinxed myself). So...I don't have a good answer for you about reliability.
The cost to repair sounds rather expensive. Was this the cost to have a repair company perform the repairs? The reason I ask is because I did a price check for a magnetron for your oven and it only costs about $80 if you order on line. That is, if you posted this under the correct model number. You may attempt to repair this yourself and save money if you are inclined to do so. Go to searsparts direct.com and type in your model number. All the parts you need are located under the "Cavity" heading. The diode you mention is listed as item 3. The magnetron is item 6. NOTE: The diode very seldom goes bad in my experience (other repairmen may argue this point).
The choice is yours. Spend $80 and repair the oven you already have, or spend a couple hundred on replacing it. What led you to believe the magnetron was bad?
I hope you find this information both helpful and encouraging. Let me know what you wish to do.
Posted on Sep 21, 2008
My microwave oven model no.jem23k004 want heat up food and makes a lod noise
Chances are you have a shorted high voltage diode or magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted or burned looking, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even though mag is bad!)
The owner's manual will tell you how long your magnetron warranty is.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's under magnetron warranty, GE will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, again you can find helpful exploded view diagrams and order parts by entering your full model number here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Oct 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave - no heats - vibrating sound
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
(it may pass the checks and still be bad)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Oct 10, 2009 | GE JE1860 Microwave Oven
Everything works, loud buzzing, no heat.
The diode is a fairly cheap fix, and your magnetron is still under the part warranty, but you would have to pay labor.
Since it's within the magnetron portion of the warranty (5-9 years) but out of the original full warranty (1 year), G.E. will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If it's within the mag warranty, G.E. should send you the magnetron to do it yourself. Call them at 888-239-6832 with your model, serial, and manufacturing date.
If nothing else, you can save about $50-75 if you remove it from the wall and take it to a GE-authorized servicer.
You can find a GE-authorized servicer by calling GE Appliance Service at 1-800-848-7620 or here.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Mar 05, 2009 | GE JVM1440 Microwave Oven
New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Nov 29, 2008 | GE JVM1631 Microwave Oven
Won't heat
This is usually a shorted high voltage diode or a bad magnetron.
You can order Samsung parts here.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
You can find your nearest Samsung-authorized service center here.
Sep 04, 2008 | Samsung SMH7174BC Microwave Oven
GE Spacemaker not heating up
I would say you have a shorted high voltage diode or a bad magnetron.
http://www.gallawa.com/microtech/xformer.html
If you don't feel confident to tackle it, GE Customer Service is here.
Aug 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore Galaxy Microwave Hood Combo Model 72180002400
Since it sounds louder than before, it is probably a bad high voltage diode or magnetron.
Sears may send you a magnetron to install yourself since it's under warranty. For that or warranty service, contact Sears at http://www.sears.com.
You can save about $75 by taking it to the shop yourself, as opposed to an in-home service call.
Aug 07, 2008 | LG MV-1444Y Microwave Oven
Sir, I have a 2 years old SANYO microwave with a stainless steel body. Some days ago it stops working. It is running well but does not heat up anything. I appreciate your comment and suggestion sent to my...
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked below.
You can contact Sanyo customer service and find an authorized servicer here: http://www.sanyo.com.au
Feel free to write back if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. "Ed" Miller, AS-EET
prototech@usa.net † http://www.MicrowaveDisplay.com
Microwave Oven Control Panel Repair Nationwide $39.95
Jun 22, 2008 | Microwave Ovens
Sanyo Microwave Oven EM_S1553
If it's a bad magnetron and your unit is within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 18, 2008 | Sanyo EM-S9515W Microwave Oven
GE JVM1650SH01 quits and asks to reset clock
Thanks musicmale -- i was gonna try the cpu board.. U saved me $$$
Just got off the phone with GE about my Jan 2005 model (not covered by the service bulletin above) They wouldn't cover the kit mentioned in the service bulletin (magnetron, stirrer and diode) but they did say the magnetron was under warranty ( even though the oven came with only 1 year warranty and its now 2 years old) They are sending me a new Magnetron for free but just in case I ordered a new Diode for $31 (WB27X1160) i din't order a new "stirrer" cuz mine is fine.
I'll let you all know if this works. in 3-5 business days.
Dan
Sep 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag MMV4205 Microwave Oven Logo
89 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
