Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
GE Nautilus wont operate
Dish washer gets 123.5volts, checked w/Fluke meter, however the display wont light up and no motor operation, no sound, basically seems dead. Is there a internall fuse of some kind? if the capacitor goes bad, will that cause the machine to completely go dead?
  • MehranZZ Sep 21, 2008
    Opened the front cover, looks like there is a spark on little circuit board that toggle switch is wired to- right next to a little resistor.
  • MehranZZ Sep 22, 2008
    On back of 12inch circuit board/pushbutton & indication display module reads: GE Model# 165D7420G001. Also, another number above it reads: TEGA 051150951.
  • 159 Answers
SOURCE: GE Nautilus Dishwasher - NO water coming in at beginning
all fill cycles on a dishwasher is timed. so at the end of the fill cycle the dishwasher may run. the first thing I would check is to make sure the water inlet valve is good. for this you will need a volt/ohm meter. you will want to make sure that there is 120v going to the valve. if there is you then would want to remove the wire connector on the valve and ohm it out. if you get a reading anywhere from maybe 450-650 the valve should be good and you will want to check for a blockage. good luck
Posted on Aug 04, 2007
  • 52 Answers
SOURCE: GE Nautilus Dishwasher soap door
Click here to view the diagram. Hopefully it will help answer your question.
Posted on Mar 25, 2008
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: GE Nautilus Soap does not dissolve
The Water Inlet Valve is not Working. This is a small piece at the bottom of the dishwasher where the inlet hose connects to. The Valve is stuck and water will not enter the dishwasher itself. Of course this is one of the most expensive pieces of the dishwasher to replace!
Posted on Jul 26, 2008
  • 160 Answers
SOURCE: Nautilus dish washer won't drain
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    ok.
Posted on Jan 06, 2009
I havn't used my dish washer in over a year and it wont turn on. Why?
check to make sure you have power to the outlet, it should be located under the sink,, if you do not have power at the outlet then check the breaker in the breaker box.
c...
Jan 02, 2011 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus- model GSD3400G00WW. Why is there standing water after the dishwasher has completed it's cycle?
i won,t too buy a g.e. dish washer model.gsd3400g00ww where can i find this model and how much it cost.
Nov 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Just put in this nautilus dishwasher which worked fine in the other house is not working now. Where is the manual restart?
check wiring is the plug in working is check gp outlets are they all reset,check brakers is the cord ok ,were the cord goes to dish washer is it secured?
Aug 29, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't fill with water
Check the power supply to the water pump through a pocket electrical line tester or volt meter.
Poer reaches and the pump mot rotating, check the capacitor associated with the motor.
May 27, 2010 | GE Nautilus 24" Built-in Dishwasher
My washer does not spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 01, 2009 | GE Profile WPRE6100G Top Load Washer
    ok.
Jan 06, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Wont start
It sounds as if your motor may have locked. Remove the lower service plate, visually inspect the motor and housing. Try to start the washer, while looking at the motor. If there is no motor movement, Turn off washer, and try to free the impellor. More than likely it is stuck and needs a little help turning
Jul 18, 2008 | GE Nautilus 24" Built-in Dishwasher
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
60 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
