Question about Roper RAS8445KQ Top Load Washer
ROPER TOP LOADING WASHING MACHINE
WASHING MACHINE WILL NOT FILL WITH WATER, IT JUST HUMS. I'VE CHECKED THE HOSES AND THEY ARE FINE. WATER WILL NOT COME OUT AT ALL.
  • 64 Answers
Sounds like the water valve stuck and humming trying to open. Check voltage at water valve should have 110 volts. If you have voltage replace valve.
Posted on Jun 10, 2009
Check the lint filter at the end of the hose. The filter is actually inside the washer. My husband cleaned it out and now ours works great. Both hot and cold had stopped running in because of our hard water.
Posted on May 23, 2009
Our Roper Top Loading Washing Machine won't fill with cold water and the machine makes a electrical buzzing noise when you turn it on set to Cold/Cold.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
Jan 20, 2016 | Roper Washing Machines
Model ras7133kq1 puddle of water on floor after using the fill hoses and drain are fine machine is level where do i start?
so you have checked your fill hoses the next step would be to remove the cabinet and run the machine to test to see where the leak is coming from here is a video on how to replace the drain pump that shows how to remove your cabinet if you have any further questions message me back and please remember when our chat has concluded in full to rank how this opinion has helped Thanks again and heres your video
http://www.youtube.com/watch?v=DwV71h86Gxw
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Top loading washing machine drips water from fill point inside machine after it is finshed load
You have a water mixing valve that is bad. Replace your valve, and install stainless steel fill hoses with fine mesh hose screen washers in the hoses where they connect to your house valves. This will prevent devbris from getting into your washer valve and causing this problem. Good Luck, Appliance Specialists
Dec 16, 2009 | Refrigerators
My Roper top loading machine will work fine on wash cycle, but will not fill up with water on rinse cycle. Please help
Check for a cold water supply problem, since it is cold water that gets used in the rinse. Remove the water supply hoses from the machine and check the small screens inside the water inlet valve. Make sure they aren't clogged with rust or debris. The solenoids can be checked using a multimeter or ohmmeter for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Aug 13, 2009 | Roper RAS6233KQ Top Load Washer
My washer won't fill up with water
SOUNDS LIKE YOUR INLET WATER VALVE HAS CHUCKED IN THE TOWEL.
WHEN YOU TURN THE MACHINE ON TO FILL UP THE VALVE OPENS TO LET THE WATER INTO THE MACHINE, IF THE VALVE DOES NOT OPEN THEN NO WATER WILL ENTER IT
THE VALVE WILL BE BEHIND THE PANEL WHERE THE HOSE ENTERS THE MACHINE
THEY ARE REASONABLY CHEAP AND SHOULD BE ABLE TO BE REPLACED BY A HANDYMAN OR WOMAN, JUST MAKE SURE YOU PUT THE WIRES BACK ON THE SAME TERMINALS AS THE OLD VALVE
Jun 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
Will not automatically switch from washing spin to rinse.
check to make sure you have both the hot and cold water lines connected and the water is turned on. sometimes the hot or cold line will clog up and it will not fill up during the rinse cycle. the humming sound may be the water valve coming on but no water is coming thru.
if you have a warm rinse set it to that to see if this is the problem.
you can clean the screens on the water valve by taking the water inlet hoses off the machine and you can look at the screens onside.
if not it may be a timer problem.
Jun 26, 2008 | Roper RAB2121KW Top Load Washer
My Roper top loading washing won't stop filling.
It's not necessarily the angle of your drain hose. When it drains as you fill it, it's called a siphon condition. Pull the excess hose out of the stand pipe (drain). Only about 6" should remain inside the pipe. Tie it down with a plastic tie to one of your fill hoses to prevent water pressure from pushing it back out. This should solve your problem.
Nov 10, 2007 | Roper RAB2121KW Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
305 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
