Display stopped working on my Hitachi AX-M68D CD Player
Nothing appears to have damaged the ribbon cable but yesterday the display in the CD Player section of the unit (the main display) stopped working. Nothing is displayed. Can't see if the display appears to be powered up because of the mirrored front.
Display stopped working mid-way through use. Other CD player functions appear ok - all buttons work.
Unit has been in storage for 1 year and was transported 200 miles but not on excessively bumpy roads.
I think the display in the Tuner section may also be a bit dimmer - it also appears to be flickering very slightly. Dunno if it helps to know that.
  • Jonathan Shorter Sep 27, 2008
    and, as if by magic, it's back on!
    thanks everyone for all your help and suggestions ;)
simplemitch
  • 752 Answers
SOURCE: Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
Posted on Sep 18, 2007
  • 31 Answers
SOURCE: Denon UDM3 SHELF SYSTEM
Hi MadLad,
There are several things to consider re this fault.....
Normally on small systems there is a selector switch to allow you to select what you need to listen to...for example if you want to play a CD then you select the CD mode, insert the CD push play and away it goes....
In your case you need to select Radio, or maybe select AM or maybe select FM, one of these should be accessed from a digital read out menu where you select your requirements.
Please have a good look at the operating manual to see if you can work out how to select the required listening mode, and you will be sweet...
Cheers From YUBEUT
Posted on Dec 25, 2007
paul_27
  • 6 Answers
SOURCE: cd not working
when u eject what dioes it say
Posted on Jan 04, 2008
SOURCE: CD player and everything works fine but there is no display .....
Well, my display went out earlier this week. Took it apart and found out that the LCD on the 501dpx was burnt out. I also found out all we have to do is replace the whole faceplate instead of the system
Posted on Apr 04, 2008
SOURCE: clock display board
Replacing capacitor C3 on the clock board will correct the dimming problem. I will cost you about $2 for the part. Replacing the board does the same thing just with a higher price tag. Unfortunately, tt sounds like you may have a bad "new" board if this problem happened as soon as you put it in.
When I had the dim display problem with mine, the oven still heated up, chimed at temp, etc -- you just couldn't see the numbers. My wife didn't like it, so I fixed it. If your old board works like mine did even though the display is dark, you could try replacing the noted capacitor and see what happens.
I hope this helps.
Posted on Apr 13, 2008
Help!! Faulty Display
The ribbon cable may not be seating correctly and works its way loose over time.
Dec 08, 2017 | Sony CDX-M800 CD Player
Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Mar 14, 2009 | Teac PD-H300 CD Player
An area on the display it's not working. PowerBook G4
I'm sorry to say that you will have to replace the screen soon. That vertical black and white lines that appear is the early warning signs that your screen will soon go blurry, or have a partial screen, or have it just stop working. This happens from the many times the screen was lifted open and closed and the ribbon cables just need to be replaced. And since the ribbon cables can't be simply unplugged and then replaced, you will just need to get a new replacement screen.
-Luke
Dec 20, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Inside display is completely dark, doesn't work.
you need a new flexable ribbon cable. try ebay or pacparts.com
Dec 19, 2008 | Pioneer DEH-P9600MP CD Player
I have a CDX-M8815X unit only works with remote commander
The problem is the ribbon cable,the one connects the face to the main board,if you live in USA you can order it from pacparts.com or sony.com.
For replace it you will need to open the unit and open the face by moving manually the gears,then remove the side screws of the face and remove face,then remove the cd mech. you will see the ribbon connector.Just replaced and put everthing back togheter.
Good luck
Nov 30, 2008 | Sony CDX-M8815X CD/Receiver/MP3 System
My DEH-680MP Stopped Working....
I just had the exact same problem today, but the radio responds to the remote and buttons on the face. I can eject cds and everything but the display will not work when the face is up. I cleaned the contacts on teh face pice with no resolution to the problem.
Mar 14, 2008 | Pioneer DEH-P680MP CD Player
Display
Possibly a ribbon cable problem to the front display from the main circuit board.
Sep 08, 2007 | Sony CDX-M8800 CD Player
KDC-MP919 No display
You probably have a break in the flexible ribbon cable that goes between the flip face and the mother board. Try partstore.com for a replacement cable.
May 24, 2007 | Kenwood KDC-MP919 CD Player
224 people viewed this question
 Grubhead
Grubhead
