Question about JVC Everio GZ-MG130 Camcorder
LENSE CAP WARNING STAYS ON EVEN WHEN IT IS REMOVED?
I cannot take any pictures or video footage because the lense cap warning is permanently displayed on the screen even when the lense cap is removed. I have reset the camera as described in the manual but cannot resolve the problem. My camera model number is actually ; GZ-MG40E
Any suggestions?
    Problem Solver:
Mine went back to JVC because it was a design problem. They fixed it for free.
Posted on Sep 21, 2008
In the middle of taking pictures, all of a sudden my Nikon P100 will become blurry and then the Lense Error message will come up saying, "Lense Error: if the lense cap is on the camera, turn the...
Could be sand particles getting into the seams around the lens barrel, binding it up. Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 08, 2011 | Nikon COOLPIX P100 Digital Camera
No picture in Viewfinder window
You have to check the shutter of the lense is opening or not if it is opening u have to change CCD base assy on the optical block
Sep 26, 2009 | JVC GR-D770 Camcorder
Lense Cap
the technology has malfunctioned
May 23, 2009 | Video Cameras
LENS CAP WARNING
JVC camcorder no picture on screen remove lens cap and unable to record problem is down to a faulty batch of ccd image sensors (thousands that Sony supplied) and if you phone the JVC servce centre (0845 3108000) and explain the problems you are experiencing its a good chance they will repair it free depending on model (I know because I have done just that and JVC are paying for it to be collected, repaired and returned totally free of charge, and mine was purchased in 2004. What have you got to lose the price of a phone call or about £70 to £90 to have it repaired yourself
Good luck syrups6
Mar 24, 2009 | JVC GR-D23 Mini DV Digital Camcorder
No subject in LCD
You have a CCD image sensor defect, it can be repaired for free. Go th link http://www.jvcservice.com/service/custnoticecamcoder.asp?Type=CCD Select your modle then click on Repair Repuest Link. Fill out the form and print two copies, ship your unit with a copy of the form to the nearest jvc repair center near you.
Mar 22, 2009 | JVC GR-D33US Camcorder
No picture
The ccd base assy. needs replacing.
Jun 29, 2008 | JVC GR-D20EK Camcorder
JVC Camcorder GR DX95EK Lense cap problem
Contacted JVC, they fix this fault free,irrespective of the age of the camera
Mar 19, 2008 | JVC GR-DX95E Mini DV Digital Camcorder
Lense Cap Error
This problem is caused by a stuck aperture assembly. The problem has occured on multiple models made by JVC (GR-DF430u, GR-DF450U and GR-DF470U). You have to have some degree of technical aptitude in order to disassemble the unit and access the part causing the problem. The tiny motor that opens the aperture flaps is not able to overcome the sticky oil/grease that JVC unwisely used on this part. Therefore the flaps stay closed, and the camera sees no light when you remove the lens cap. This makes the camera think you haven't removed the lens cap, causing the "lens cap" error.
If you feel like you have the skill and you are careful, you can disassemble the unit and clean the part yourself. It takes longer to take the unit apart and put back together than it does to clean the sticky oil off the part.
If you contact me, I can send you a diagram of where the part is located that you need to access. This is not recommended for amateurs, as you can damage the unit and cause other problems if you aren't somewhat skilled in disassembly of electronics.
Mar 03, 2008 | JVC GR-DF450 Mini DV Digital Camcorder
Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
Warning Lense Cap On
This will sound crazy, but I just read the section under "Tips and Tricks" entitled, "Freezing". Users there recommend dropping the camera (gently) about an inch down onto your mousepad, or squeezing the casing of the camera, expecially around the battery. I squeezed the camera around the lens and Viola!, no more problem.
Nov 09, 2007 | Nikon Coolpix 885 Digital Camera
JVC Everio GZ-MG130 Camcorder Logo
100 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
