Question about Mitsubishi WS-65857 65" Rear Projection Television
Power loss turn tv on it shuts right back off green light comes on for five seconds and shuts right back off any sugestions same. turns on for a few seconds and shuts off
  • Kenny_Sr Sep 25, 2008
    Tried your suggestion but did not work
    Guru:
  • 558 Answers
Check for short pin 2 to 4 ground on vertical def.
Took off the cover and disconnected the switch wires. If there was no change. Then just started going through all the menu choices, and (i think) the a/v reset did the trick.
Bottom line, if complete control of the system back. Let me know if you need further assitance.
Regards
ELLIN
Posted on Sep 20, 2008
  • 1 more comment
  • Puneet Jain
    Puneet Jain Sep 20, 2008
    Hi
    It assuming to be tube is out and it could be. the reason. Then it is time for a new tv
    for sure.
    The other reason may be the circuit in the tv that could cause this is the
    video driver circuit. a repair on this would range around 250.00 or so.
    Now last thing is a loose cable from your cable box to the tv. If there are more cables from the switch box to the TV one could be loose.
    Now
    if you are running straight cable then this is not a issue. hope this
    helps?
    Just let me know if this help you out.
    Have a great day!
    Regards
    ELLIN
  • Puneet Jain
    Puneet Jain Sep 25, 2008
    Hi There,
    Thanks for your reply.
    The Mitsubishi 525 series, 725 series, and 825 series DLP TVs display all signals at a 1280 x 720p resolution.
    Mitsubishi ALPHA Series LCoS TV displays all signals at a 1920 x 1080p resolution.
    So please check out the resolution and adjust it first. Also let me know about the warranty period.
    Regards
    Ellin
  • Puneet Jain
    If the lamp fails in a Mitsubishi MicroDisplay TV, there will be no
    picture on the screen and a red front panel LED indicator will
    illuminate.
    Regards
    Ellin
  • 360 Answers
Try to let the set sit for 15-20 mins. this will reset the computer. good luck
  • Jimmy
    Jimmy Sep 20, 2008
    unpluged sorry........
Sony trinitron kv-es29m80 tv has no led light
The blinks are fault indication. If the standby light blinks 10 times and the set shuts down after that;
Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board
Apr 12, 2012 | Televison & Video
My toshiba 40ft2u1 will not turn back on
I'm having the same problem right now. I get the green light for about 5 seconds (not Blinking) then the light goes out. No sound or picture.
Apr 05, 2012 | Toshiba Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Power loss
Check for 12v on Q5A33 110v on Q5A01 this feeds T5A31 that powers the CRT filaments make sure Diode DA52 isnt open and also check horizontal output Q5A31 for being shorted or open. let me know if you need any more info.
Feb 02, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Power loss
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Nov 30, 2006 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WS-65857 65" Rear Projection Television Logo
56 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
