Question about Dell Dimension 8200 PC Desktop
Cd rom drive
Hi there I need to know where to get a cheap cd rom drive for a dell dimension desktop. I can get one off of dell, but I need to know what the model number is so I can order it. Please let me know if you can help.
  • Mandy Lynn
    Mandy Lynn Sep 21, 2008
    Thanks for your advise. It help me a lot.
    Problem Solver:
  • 9 Answers
Best place to go is www.newegg.com brand or model is your preference. The only thing you need to know is if you have sata or ide interface. If you need to find out just open your case look at back of old drive sata will have 2 small cables, ide will have a ribbon cabble & multi colored cable. To swap out simply pull out old drive & look at jumper position on old drive place jumper in same place for new drive. Plug in cables put in case & your done. Windows will recognize & install drivers automatically. You do not have to install software that comes with it unless you want to. Be sure to shut down computer & unplug power cable from back of computer 1st.
Posted on Sep 26, 2008
    Guru:
  • 558 Answers
Hi
Please use the Cd/Dvd Drive with the following specification:
CD-ROM/DVD-ROM/Disk drive
8X max DVD+/-RW Drive with DVD+R double layer write capability
Or
16X DVD-ROM drive, 16X/10X/40X CD-RW drive
Regards
ELLIN
Posted on Sep 20, 2008
  • Puneet Jain
    Puneet Jain Sep 26, 2008
    Very helpful to a computer newbie.
I need to buy replacement internal cd-rom for my Dell Dimension 8110
Any IDE CD-ROM Drive will do just fine... Just make sure you configure the jumpers according to your specific setup (look at the old drives jumpers if you don't know).
Dec 05, 2010 | Dell Dimension 3100 PC Desktop
Will a Lite-On 22x DVD+/-RW Double Layer IDE DVD Burner Drive - IHAP122-04 fit in my Dell Dimension 2350 as replacement for my CD drive ?
Definitely, yes. Yes it will fit in your system without any problem. Just remove the Cd-Rom drive and install the Lite-On. If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Aug 23, 2010 | Dell Dimension 2350 PC Desktop
Need to replace cd-rom drive, how difficult?
CD-ROM drive can be taken out by opening the tower side cover. ther is a cord at the back of the drive which needs to be pulled out. then from the front side pull the drive out. also be careful to check it has some screws at the side or not. if not then it should come out easily.
May 10, 2010 | Dell Dimension 3000 PC Desktop
Need to replace cd-rom drive, how difficult? dell dimension 3000 pc desktop
It is not difficult to change cd/dvd drive.
Open cpu cabinet.
Then remove icd cable and power cable from cd/dvd drive.
Then remove screws of old cd/dvd drive.
Then you can pull it from cabinet from front side.
Then put your new cd/dvd drive into it's position then lock it with screws.
Then connect ide cable from motherboard and power cable to drive.
Then you can use it.
If you connect to drive with 1 ide cable means if you connect harddrive and cd/dvd drive with 1 cable then set harddrive as master and cd/dvd rom as slave you can set it slave with jumper settings.
It is in back side of cd/dvd drive.
There is instruction how to slave it with jumper.
Let me know if you need further assistance.
Mar 17, 2010 | Dell Dimension 3000 PC Desktop
Dvd-rw does not work when inserted in D drive the message returns "please insert DVD into drive"
Hi! You may have a problem with the optical drive/CD rom drive. The lens may be dirty so i suggest you run a cd lens cleaner. If it still doesnt help, I believe you need to buy a CD rom replacement. Hope this helps.
Mar 11, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I have a dell dimension 3000 desktop and the sound from the cd/dvd rom drive is distorted or choppy when i play a dvd rom or a cd
hi go to start, settings, control panel, click on sound and audio devices. on the volume tab locate properties and click on it. now another box will appear look for cd volume and adujst it whist playing a cd until the sound is less distorted. please rate me if this solves you problem.
Feb 23, 2010 | Dell Dimension 3000 PC Desktop
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
CD-ROM drive doesn't acknowledge DVD-ROM, what's wrong?
CD-ROMs dont play dvd becuase they are not designed to read dvd.
If a dvd drive for your model is not available, you can buy an external usb dvd drive.
That should solve your problem
Dec 28, 2009 | Dell Dimension E521 PC Desktop
Dell Dimension 5150 cd-rom stopped working
Open your tower and reseat all the cables that are running to the CD ROM (generally a flat white cable). Also reseat the other end of the cable to the motherboard too.
Ensure that CD Drive is enabled in BIOS (Press F2 as the system boots up to enter into BIOS) Please get back if you need any further help.
Jan 09, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 8200 PC Desktop Logo
119 people viewed this question
Alun Cox
