Question about Microsoft Windows Vista Ultimate Edition
Windows vista hey man!!! i really need your help again:D i need t know which of vista x32 x64 x86 is better to install on a conroe intel core 2 duo 2mb cache fsb 800 and a gigabyte main board with 2 gb ddr2/800 memory...i appeciate all your help and thanks a lot!!!by the way i bought a nvidia bliss gainward 9600gt video card:D it's on the same system!!! thanksssss!!!!
  • elnino_alexx Sep 21, 2008
    dear friend i've installed a 32 bit windows vista on my pc.i have a really bad problem because errors appear when i surf the internet and most importantly i receive a blue screen with white writing that says "invalid acces to memory or physical memory" something like that and i'm desperate!!!
    what can i do?my memory is 2gb ram ddr 800
    thanks and we'll talk soon!!!!!!!
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask me" again and likewise the previous ratings.
To my knowledge, Vista x64 is just an x32 with 64 bit addressing. Some have reported that 64 bit on a Core 2 Duo isn't a very good idea with the extra speed gain of x64 over x86 being marginal for now. Offhand, you might be better off still with X32 at least for the time being.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 21, 2008
  • Louie  Role
    Louie Role Sep 23, 2008
    A couple of things to try:
    • config the CMOS/BIOS to default;
    • check/clean/interchange the memories;
    • check/verify/update your motherboard/chipsets drivers.
Which is the perfect OS x86 or x64 for intel core i3 cpu 530 @ 293 ghz
The i3 cpu is a 64 bit processor, therefore it will suit 64 bit Windows OS.
Jan 29, 2012 | Intel Core i3 530 293 GHz processor
Does Microstar MS7525 motherboard support Intel(R) Core 2 Quad Q8300 cpu and ATI Radeon HD5450?
Hi, you can see some info here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01386897&lc=en&cc=us&dlc=en#N280
As far that i can see you can not use the Quad core cpu
in this mainboard.
Motherboard supports the following processor upgrades:
  • Core 2 Duo E7xxx (Wolfdale-M)
  • Core 2 Duo E4x00 (Conroe)
  • Pentium E2xxx series (Conroe)
  • Celeron Dual Core E1xx0 series (Conroe)
  • Celeron 4xx series (Conroe)
But you can use the graphic card as long it is PCI-E.
Aug 31, 2011 | HP Compaq Motherboard
I'm having 512mb of ram can install .net on this and please send details to install .net package in a system.
Hello For .Net Framework 4.0 following are the pre requisite:-
System Requirements Supported Operating Systems:Windows 7;Windows Server 2003 Service Pack 2;Windows Server 2008;Windows Server 2008 R2;Windows Vista Service Pack 1;Windows XP Service Pack 3 Windows XP SP3 Windows Server 2003 SP2 Windows Vista SP1 or later Windows Server 2008 (not supported on Server Core Role) Windows 7 Windows Server 2008 R2 (not supported on Server Core Role)
Supported Architectures: x86 x64 ia64 (some features are not supported on ia64 for example, WPF)
Hardware Requirements: Recommended Minimum: Pentium 1 GHz or higher with 512 MB RAM or more Minimum disk space: x86 - 850 MB x64 - 2 GB
Prerequisites: Windows Installer 3.1 or later Internet Explorer 5.01 or later
If you fulfill above requirement then go to http://www.microsoft.com/downloads/en/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
and click on download, you will found other instructions over there
Good Luck, do rate the solution if got help
Dec 31, 2010 | Computers & Internet
How can i use oracle in win 7 platform of i3 processor?and which processor is best core 2 duo or core i3?
Windows 7 Release Candidate was publically released on May 5, 2009. This should be the final release before it goes live later this year. download it, install it in a VM inside of VirtualBox and try to install Oracle on it. There is no Oracle release for Windows 7, so instead grab the Windows 2008 one. The install is pretty straight forward. The only "gotcha" is that if you go to the command prompt, you need to run it as the Administrator, so that all of the Oracle commands will work (lsnrctl, dbca, netca etc...) Really there is not that much to it as it was pretty seemless. So, if you download Windows 7, then you can also download Oracle 11g and start playing with it today!
Here is the second answer
We live in the times where computing power, once available only at the level of super computers, has been made available to the common man. The forerunner in the race, who's probably miles ahead of its competitors is the computing giant Intel. According to the needs of computer users, Intel delivers chips with varying degrees of power and clocking speed. These include the entry level, mid level and high end processors. The latest entry level Intel chips to hit the market are the core i3 processors which are aimed at taking up the place previously held by the core 2 duo processors. The new hierarchy of Intel chips in ascending order of computing power are the core i3, core i5 and core i7 processors. Although core 2 duo processors are slowly being phased out of production, they are still available in the market. In this article, I present a core i3 vs core 2 duo review which may help you decide which one to go for.
Intel Core i3 Vs Core 2 Duo Comparison
A comparison between processors was simple some years ago with a single core processor. All you had to look at was the clocking frequency and the cache size. The entry of multiple core chips changed it all and life became complicated. With dual, quad and even six core processors hitting the market, there are many more factors to be considered than before. Intel's dual core and core 2 duo processors were the first ones to introduce the multicore processor computing power. The quad processors created later have given rise to the quad core vs dual core debate, as well as the core i5 vs core i7 comparison which is something that high end computing market consumers should think about. Prior to that, we only had the 32 bit vs 64 bit processors comparison.
Today, Intel has gone through a lot of designing and planning to introduce core i3 processors that are an improvement over the core 2 duo processors. The following Intel core i3 vs core 2 duo processor comparison will give you an idea about how the i3 processors are different from their dual core predecessors. The two points of comparison will be technical specifications and the only other factor which matters that is performance.
Core i3 Vs Core 2 Duo: Technical Specifications
Like the core 2 duo processors, the new core i3 line of processors, have two cores with many other technological enhancements including an integrated GPU (Graphic Processing Unit). The clocking frequency of the core i3 series of processors ranges from 2.26 GHz to 3.06 GHz. Each processor is endowed with the new line of advanced technologies including Intel developed hyperthreading, Intel virtualization and smart cache technology which makes these chips faster than core 2 duo processors. This is the most important point in the core i3 vs core 2 duo comparison.
The Intel codename for core i3 architecture is Clarkdale. They are based on the Westmere architecture with 32 nm fabrication and a direct media interface (DMI) bus. The socket type used for core i3 processors is LGA 1156 and the RAM type is DDR3. They support mother boards with the following types of chipsets- H55, P55, H57 and Q57.
Let us have a look at the latter processors in the core i3 vs core 2 duo comparison. Core 2 Duo processors come in three types of architectures, codenamed as Conroe, Wolfdale and Allendale. With 65 nm and 45 nm fabrications they are a tad slower and less power efficient than the 32 nm based core i3 processors. The socket used for core 2 duo processors is LGA 775 and they come with a FSB bus. The FSB bus is a lot slower in operation than the DMI bus in core i3 processors.
Coupled with the fact that the i3 processors have a L2 cache size of 2 x 256 kb and a L3 cache size of 4MB, with hyperthreading and smart cache enabled, core 2 duo processors are indeed slower. On top of that, DDR3 RAM compatibility in core i3 processors, compared to DDR2 compatibility of core 2 duo processors makes them even more faster. The price range of Intel core i3 is $100 to $133, which makes them top options in the entry level market.
Core i3 Vs Core 2 Duo: Performance
The technical specifications have made it clearly indicated that Intel core i3 beats its predecessor, core 2 duo in almost all departments. This is but natural as they were indeed designed to replace them. Be it processing speed, multitasking or graphic output, opting for core i3 processors is the logical choice to make!
Hope the core i3 vs core 2 duo processor comparison provided in this article has made it easier for you to choose the right processor for your personal desktop computer or laptop computer. Going for a more advanced line of processors is always beneficial in the long run. You should also check out the Intel core i5 and core i7 processors before going ahead as they offer far more computing power and speed, compared to the entry level core i3 or core 2 duo. Decide on the processor you want according to your usage requirements and of course giving due thought to your vitamin 'M' levels!
Dec 16, 2010 | Intel Core i3 540 306 GHz (BX80616I3540)...
Can the Dell Latitude D610 run any of the following games: Age of Conan Star Trek Online Champions Online Aion
Check your system if it meets the following requirements
Age of Conan
Required
OS: Windows Vista/XP
Processor: 3GHz Pentium IV
RAM: 1GB RAM
Video Card: Shader Model 2.0 and 128MB RAM: NVIDIA GeForce 5800 or ATI 9800
Recommended
Processor: Intel Core 2 Duo 2.4 GHz (E6600) or better
Video Card: NVIDIA GeForce 7950GX2 or better
RAM: 2GB or more
Enhanced for: DirectX 10, 64-bit processors, multi-core
Supports Parental Controls on Windows Vista
Start Trek
System Requirements
  • OS: Windows XP SP2 / Windows Vista / Windows 7 (32 or 64-bit)
  • CPU: Intel Core 2 Duo 1.8 Ghz or AMD Athlon X2 3800+
  • Memory: 1GB RAM
  • Video: NVIDIA GeForce 7950 / ATI Radeon X1800 / Intel HD Graphics
  • Sound: DirectX 9.0c Compatible Soundcard
  • DirectX: Version 9.0c or Higher
  • HDD: 8GB Free Disk Space
  • Network: Internet Broadband Connection Required
  • Disc: 6X DVD-ROM
Recommended System Configuration
  • CPU: Intel E8400 Core 2 Duo or AMD Athlon X2 5600+
  • Memory: 2GB RAM+
  • Video: NVIDIA GeForce 8800 / ATI Radeon HD 3850+
  • Disc: 6X DVD-ROM
To check your system hardware> click on start>all programs>accessories>system tools> system information.
Thanks for using Fixya
proton
Mar 27, 2010 | Dell Latitude D610 Notebook
Hey i am using windows 7 ultimate rtm(x86) 30 days trial ver. I hv an intel original 945 chipset with on board souncard. I downloaded the realtek HD audio sound drivers for windows 7 x86. But only the...
hi, to fix that problem you need to download the exact name of the sound card that compatible for windows 7, if you can't find it, its better to use only your vista or windows xp. it is only compatibility of windows 7 some driver won't of it//
regrads
Mar 18, 2010 | Computers & Internet
SONYVAIO-PC
You dont need any driver since your PC is configured as x64 bit processor so all you got to do is get hold of the XP OS which is meant for x64 compatible PC's. The one normally used is 32 bit named as x86. I hope u wont face any difficulty in getting hold of x64 based OS(XP)......sodeep
Jul 30, 2009 | Computers & Internet
My lexmark x8350 series won't work on windows vista
According to lexmark's site, uninstall all lexmark software, then go to:
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
and type your model number in the search field, then you will need to choose either vista x32 or x64 for 32 or 64bit and download and reinstall the drivers
Jul 11, 2009 | Lexmark X5470 All-In-One InkJet Printer
I just wanna kno if my GTA4 is gonna work smooth in full grafics with this card..
Well without knowing the card, i can tell you this.
I have a 8800gt 512mb, 4gb's ram and a 3ghz c2d e6600 and i get an average 42fps using the in game benchmark. It depends really what resolution you want to play at. I play at 1440 x 900. You would need at least a nvidia 8600gts or Ati equivalant card to play the game. Also a core 2 duo is definately needed to play this game smoothly- better yet if you have a core 2 quad. If you are using a laptop then I could almost certainly guess that it wont work. If you have a pc using intel graphics then it wont work either.
May 17, 2009 | Computers & Internet
No Taskbar
The taskbar is always running in Windows Vista. Unlike Windows XP, it can't be unlocked and hidden unless the 'auto-hide' feature is turned on. If 'auto-hide' is on, simply run your cursor along the bottom edge of the screen and the taskbar should pop-up.
To disable auto-hide, after moving your cursor to bring up the taskbar, right click the taskbar and click properties. Then under the Taskbar tab, uncheck auto-hide.
If auto-hide is off, it may indicate that explorer.exe is not running/has crashed. In order to restart explorer.exe you can either
1) Restart
2) Press CTRL+Shift+Escape, File -> New Task and then type in explorer.exe and run
Feb 01, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
