Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis black oil like residue and can't remove agitator
Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please comment
  • 750 Answers
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
I'm getting small orange spots/stains on my clothing after washing them in my Maytag washing machine. it is a 2010 machine too. Any thoughts as to what could be causing the stains?
Unless there is a child's crayon or something similar causing it, then suspect that the agitator shaft seal, or the drum seal is leaking oil into the drum. Hopefully, there is still warranty on the machine. Good luck!
Jan 10, 2011 | Maytag Centennial MTW5800TW Top Load...
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Leaving black residue (spots) on clothing
Black spots usually come from the agitator shaft bearing seal which will, when worn, allow oil from the transmission to seep into the wash. Replace the seal, and maybe the upper bearing if the shaft itself will move visibly from side to side in various directions. If the machine is still under warranty, take advantage. Hope this helps!
Apr 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis will not agitate it runs through all the cycles it will spin but will not agitate. The belt is intact.
WELL THATS BECAUSE ITS AGITATED WITH THE XTRA LOAD YOU PUT IT THROUGH WHEN YOU ARE SITTING ON IT NOW I KNOW ITS FUN BUT SPIN CYCLE IS ONLY DESIGNED FOR WASHING CLOTHS...I HOPE THIS ADVISE FIXED YOUR PROBLEM.
Oct 31, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 noise when on and agitator doesn't work.
it does sound like a bad motor.
they are rather expensive on that machine,
you would be looking at 300 or so
May 28, 2009 | Maytag Atlantis MAV6451 Top Load Washer
A piece of clothing is stuck underneath the agitator! It won't turn during the wash cycle. The spin cycle still works. How do I disconnect the agitator, so I can remove the piece of clothing?
remove the agitator by first taking off the softner dispenser at the top of the agitator and then look down inside. inside you will see a half inch head bold. remove bolt and lift agitator out.
Jan 27, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Apr 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
514 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
