Question about Sony Ericsson W300 Cellular Phone
Phone says usb connected but its not connected it wont let me use phone
Every time i turn my phone on it say do not remove usb cable but the thing is its not connected so i don't know what to do.
    Brigadier General:
  • 7,752 Answers
Try master resetting all on the phone or reflashing the firmware
Posted on Sep 20, 2008
LG Optimus L9 Screen blacks when charger/usb-to-computer cable plugged in.
sounds like you have a usb cable for charging only.You need a "2 way " usb cable,the kind used to transfer music and pictures to and from phone to computer.These one way cables are usually used in mobile chargering,as you don`t need to transfer things,just charge.Or you got wrong cable for your phone.
Mar 02, 2014 | LG Optimus Black Smartphone
My i phone 4s wont charge past 70%
The First solution is that plug and plug tour Charging USB cable. it should work.
nd change the USB Charging because the USB cable pin become week after some time. and also download Battery app for ur Iphone it will tell u every thing. :)
Dec 10, 2013 | Apple iPhone Smartphone
My samsung galaxy pocket won't turn on!!
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 29, 2012 | Cell Phones
Myhpj4680 printer wont stop printing the same thing over over over
What print it is?. >Might be askew codes are printing. remove usb cable, cancel all the pending documents, un install the drivers. Once system cleared every thing restart the system,load printer drivers with original cd..when system asked to connect the printer.. Switch off the printer wait couple of minutes..connect the usb cable.. complete the drivers installation..check for print..
Jan 31, 2012 | HP Office Equipment & Supplies
Hello, My samsung tocco ultra touch screen is frozen. It wont respond. Also the call button and the return button(the centre one) dosent function. I tries almost all options like switching off-on,...
Hello.
It could be a software problem (but you can't connect by USB cable) or a hardware problem. Unfortunately without proper tools you can't fix either. You just have to take it to a Samsung service.
Regards, Achil
Mar 09, 2011 | Samsung Tocco Ultra Cell Phone
I tried to reset my bb by removing my battery and putting it back in, but it wont boot up, just flashes a red light. have tried to connect to pc, wont recognize. have tried resetting several times...
Hopefully you have sync'd the BB before this happened.
1) uninstalled DM4.7 (this also fixed the annoying virtual serial port issue)
2) deleted/uninstall the BB4.2 and BB4.5 versions previously installed onto the computer
3) downloaded and installed DM4.5,
4) installed BB4.5
5) removed the vendor.xml file
6) with the phone disconnected, put in the battery for a split second until the solid red LED shows, then connect the mini-usb cable to the phone and at the same time take the battery back out (this seemed to be the only way to make the PC 'detect' the phone)
7) run Application Loader, which detected my BB4.5, and updated the phone's OS/software/apps
8) near the end ,when the app loader says something like "connecting to phone" or something like that, put the battery -back- into the phone
9) this seemed to initiate the installation of the phone's core modules, a 10 minute process or so
10) after that you get the rotating hourglass thing on the phone's screen, and after waiting about 20 minutes or so, VOILA!!
Nov 26, 2010 | RIM BlackBerry Pearl 8100
USB cable,pc suit is not connecting to the computer.
properly install pc suite.then connect your phone using usb cable.while connecting keep in mind that,cell phone should not be switch off,or unlock. some times even if u hav done every thing properly,some times usb cable should be see as not recognisable then u can opt trouble shooting...
Oct 16, 2010 | Cell Phones
Sony ericsson w580i phone lock code
Open up XS++
Then connect the phone while holding "C", afterwards use the GDFS opiton to read the code wink.gif
Make sure you have USB FLASH DRIVERS INSTALLED
HOLD "C"!!!!!
AND FIND USB FLASH DRIVERS HERE !
1. Powered off the phone
2. Taken the battery OUT.
3. waited 30 seconds to a minute,
4. started XS++
5. Clicked on Connect on XS++
4. HOLDING C button
5. Connected the USB Cable,
6. waited for some time, got message no phone detected.
Tutorial VID
Let me know.
micro
Aug 16, 2008 | Cell Phones
Sony ericsson w610i
Go to Sony site and download the driver for your phone
http://ma3-origin.extranet.sonyericsson.com/drivers/
Step 1
Remove data cable from usb and put it into a different one
Step 2
Connect your phone to the computer with the cable and turn it on.
You might see "Found New Hardware" wizard. DON'T let Windows search for the driver; point it to the driver you just downloaded, and install the drive on your computer.
After the driver as installed you should be working 100%
Jan 09, 2008 | Sony Ericsson K610i Cellular Phone
Sony Ericsson W300 Cellular Phone Logo
123 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
