Question about Panasonic VS6 Cellular Phone
Housing I'M using Panasonic VS6 cellular Phone. The cover of the battery is missing and i can't get the housing. How can i get it since i can't stop using this phone ? Kobby
I did manage to find a website a couple of years ago that sold Panasonic mobile sparea and bought a new battery cover when I had lost mine.Try searchng web for Panasonic Mobile Spares you might get lucky.
Posted on Dec 23, 2008
Unable to update profile settings automatically for wap and GPRS
kindly use this link for your problem www.theiia.org/guidance/quality/qa-manual.../qa-manual-dwnld---spanish/ -
May 27, 2011 | Panasonic VS6 Cellular Phone
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
My panasonic phone display which to Spanish and
try restoring to original setting ,phone will restart @ that time click the language selection as english
May 13, 2010 | Panasonic VS6 Cellular Phone
Removing cover to motor
You will have to access the motor by removing the entire bottom brush housing and tilting the vac motor shaft out of the housing. Once released you will have a main body and brush housing.
There are visible motor housing screws in the lower portion of the main housing and if I recall there may be twoscrews inside the bag chamber as well
Sep 09, 2009 | Panasonic MC-V5209 Vacuum
I need password of program sercurity
1111 or the last 4 of your phone number
Jun 17, 2009 | Panasonic VS6 Cellular Phone
I have nokia 6255 cdma from reliance set
no u cant..ur mobile is non sim based,,u can take new mobile n transfer to nonsim to sim
Jan 09, 2009 | Panasonic VS6 Cellular Phone
Network
i believe what is happening is it might not be compatable to use in your country. may be a cdma phone or only 2gsm compatable.
Jan 25, 2008 | Panasonic VS6 Cellular Phone
Panasonic vs6
if you can take the key pad off from the phone there could be dust stuck underneathe. if not then it needs to be repaired by the manufacturer. youcan do this by getting in contact with where you purchased the phone
Dec 20, 2007 | Panasonic VS6 Cellular Phone
Where can i find a back cover??
Currys online do panasonic spares cost of new cover is £2.99
Panasonic VS6 Cellular Phone Logo
Top Panasonic Cell Phones Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
