Related Tags:
This problem should be removed because:
Problem with Maytag 26 cu. ft. Wide-By-Side Refrigerator - 36" - Stainless Steel
replaced water filter but can't get red light to turn off.
Solutions (1)
Best Solution
Hello there and welcome to fixya
This is a rather easy fix please try this
Maytag and Jenn-Air - press and hold the lock and light buttons (lock and water on newer fridges) on the dispenser for about 4 seconds, until the indicator light blinks.
Suggested Solution (3)
You have to reset the light by pressing and holding the touch pad for 3-5 seconds. It doesn't reset on its own when you replace the filter
Source: Water Filter light still red after new filter installed
try holding ice type and child lock together for 3 seconds that worked on mine
Source: filter light still on "Red"
Not positvie for that model but there should be a little reset button, or try just unplugging the unit and waiting 60 secs before plugging it back in. Hope that helps
filter light on door is still on "Red" not "Green" after changing filter = Maytag Puri Clean filter UKF7003AXX. * the...
changing light after installing new water filter
Installed new water filter, how do you change the red indicator light to green?
change filter light
I changed out the filter inside the refrigerator, but the red change filter light will not go off. There is no visibile reset switch or...
red light stays on after changing the water filter
red light stays on after changing the water filter and running about 2 gallons through it
I am replacing the water filter how do I reset on
I am replacing the water filter how do I reset on the outside door
Add Your Solution
I have rust on the freezer door and water/ice does
I have rust on the freezer door and water/ice does not shut off
my ice dipenser is stuck on crush
I have a maytag side by side with ice and water dispenser in the door, my ice dipenser is stuck on crush
Related Topics
Fix-O-Meter
59
59 people viewed this problem
- 3 people found this problem to be helpful.
- 2 people are following this problem
Top Maytag Refrigerator Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
