Question about Maytag Neptune MAH5500B Front Load Washer
Washer shutting off
The washer will shut off after about one minute of running the door lock will not come on and I dont seem to hear water running in the machine
  • duback5 Sep 23, 2008
    We blew a fuse while the washer was in mid cycle - now it will not start again - showing "door lock" when you hit start. It sounds like the lock engages and then releases. How do you finish the cycle?
    Sergeant:
  • 409 Answers
can you tell me the model # and are there any error codes on the display?
Posted on Sep 23, 2008
My Front Load Affinity washer shuts off after a few minutes
Good Afternoon Lori - Thank you for your post! Based on the symptoms you are describing, you may either have a communication error from the main control board or the timer itself may not be operating correctly. If you noticed a humming noise, then once again it could either be a clogged drainage hose or pump that needs to be cleaned, or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jul 11, 2013 | Frigidaire Affinity ATF7000E Front Load...
Water fill and start
if the water valve is bad it will hum and no water will enter the washer,first thing is to see if it's a problem with the houseicon1.png water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
We have a whirlpool duet sport washer, the machine is powered on as evidenced by the lit up control panel's LED but when we try to run a cycle, the machine refuses to start and after a couple minutes it...
do you hear the door lock assymbley locking if not then either you have a bad control upper board central control unit uper grey board located top back of washer ........or bad door lock assy
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
2-yr old troy-bilt pressure washer with honda gcv160 engine. seems to run well, but when trigger is pulled get full pressure for less than 5 seconds before reducing to house water pressure. when left...
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Jul 17, 2009 | Briggs & Stratton Garden
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Water in door takes over a minute to BEGIN flowing.
I had the same problem.... Until just one day the water quit working... Always thought it was hard water build up blocking the waterline.... Come to find out several years later all it was, was the dual water valve that had gone bad... I guess they have a censor in them that will either lock open or lock shut.... Mine was locked shut... When I tried to fix the valve myself, by opening it up and blowing air threw it, I locked it open and when I conected it back up to the fridge water was coming out of the door uncontrolably. So I ordered a new water valve.. Replace it myself... Works great now.... Hope this helps...
Apr 06, 2008 | Amana ASD2326HE Side by Side Refrigerator
Door jam!
Probably you need a new doorlock. I really dont have a good answer how to open the door with this problem.
Jan 24, 2008 | Electrolux EW1000i Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
