Question about Eurocom 888es Notebook
Eurcom 888E wont boot past the bios screen
HI
Need some urgent help. I've got a Eurocom 888E and it's been fine for years.
But now when I switch it on it goes through the Bios page very quickly and then to a black screen with the a cursor in the corner.
It will go no further and when I try any keys it just beeps. Ctr-Alt-Delete just start it up again with the same result.
The only problem i had before was that I was getting an error about a disk being inserted that wasnt actually in the CD drive.
I'm a bit clueless so you'll have to quite clear on what I can do to get my baby up and running.
Please help!
Bon.
  • 5 more comments
  • BonChakram Sep 21, 2008
    Hi Robert
    Thanks for the tip. Unfortunately that hasnt worked. Nothing happens - just goes through the Bios screen and then to the black screen with a flashing underscore (same as before).
    Then beeps when try push any keys.
    Any other suggestions?
    I've got the CD with the drivers on that came with the laptop - will that help anything?
    hi Robert
    I've tried to start it up without the power cable - didnt work. I've now removed the battery and I'm waiting for a bit....
    hey again
    Removing the battery, waiting and switching her back on didnt work :(
  • BonChakram Sep 22, 2008
    No nothing happened when I tapped the F8 key.
    It goes through the Bios screen really quickly. How do I stop it to try control it? I've tried ctrl-alt-delete that just reboots and it goes through the Bios screen with the same result.
  • BonChakram Sep 23, 2008
    hi again
    I pushed Ctr-Alt-S this took me to a screen with the settings. No sign of a date except the current one :(
    cool. the time reflects what it is in the uk right now.
    Gonna give you all the info on the page - I dont know what most of it means.
    Devices:
    Floppy Drive A=1.44MB
    Hard Drive C=40010MB
    Hard Drive D=0MB
    Hard Drive E=0MB
    Hard Drive F=0MB
    Serial Port 1 = COM1, 3FB, IRQ 4
    Serial Port 2 = COM2, 2FB, IRQ3
    Parallel Port = LPT1, Addr 378, IRQ7
    System:
    CPU Clock= 2400MHz
    Memory:
    Base=640KB
    Extended=523264KB
    Shadow=64KB
    Reserved=320KB
    Total RAM=524288KB
    Cache (Ext)=512KB
    Does that help at all?
    Hi robert
    Not sure where the bios battery is, but nothing changed when i removed the cord or the normal battery.
    If i restore the factory settings then I'll have to reformat the hard drive and reinstall windows? Will this mean that I wont be able to get all my stuff off the laptops - documents and music?
    Is there a way which i can "download" my docs and music off the hard drive before?
    Brigadier General:
  • 5,158 Answers
Reboot the computer as soon as you see signs of life start tapping the f8 key. when that screen pops up try to boot to safe mode or last known good configuration.
Robert
Posted on Sep 20, 2008
  • 4 more comments
  • Roberta Smith
    Roberta Smith Sep 21, 2008
    topic appears to be laptop so unless you have a desktop this won't likely work.... unless you know where the bios battery is... but even so.... pretty simple thing to try.... remove the power plug and battery if it is a laptop.... wait five or ten minutes and plug it back in and power it up.
    i have some other things you can try but lets start there ... i've got coffee and i'll be here for the rest of the day.
    Robert
  • Roberta Smith
    are you comfortable enough to go into the bios ?
    and nothing when you kept tapping the f8 key eh ?
    Robert
  • Roberta Smith
    Roberta Smith Sep 22, 2008
    When it boots up there will be something written there to enter the setup (bios). a little hint is if the screen goes by too fast.... hit the pause key on your keyboard. I don't want you to change any settings there yet. but in the first selection in that menu on the left side. i need you to hi light it and hit enter. use your up down keys on your keyboard to get to it. i'd like you to check the date and time. also is it showing a hard drive as being detected. ?
    Robert
  • Roberta Smith
    Roberta Smith Sep 23, 2008
    ok... the settings screen is a good start... in other words the bios.... you will see a menu divided into the left and right.... use your up down key to hi light the one you want.... pick the first choice on the menu on the left.... hi light it then hit the enter key..... it should show you the system time and more importantly if it has found devices such as your hard drive and cd rom etc.... there should be a list of them..... the setting should be on auto... but i'll leave that till you confirm it has found the devices
    Robert
  • Roberta Smith
    Ok.... when you removed the battery and the power cord were you able to remove the bios battery at the same time ? one other thing you can try is to restore the bios to the default settings and then save them. i cannot recall exactly the words used in the menu. but if you cannot locate the bios battery. you might try this.
    Robert
    P.S. after this is likely having to format your hard drive and reinstall your operating system
  • Roberta Smith
    First basically what it appears to need is for the bios battery to be unplugged as well. removing the battery and power plug doesn't completely do a reset on a laptop. ... i can try and find the service manual for that computer later on today. boot back into the bios and restore the bios to defaut... hit f10 the yes... reboot and see what it does.
    if that does not work you would probably have to format the drive and reinstall your operating system. yep you would lose everything.
    I do data recovery and i suspect that i'd recover what you are after but i do that for a living so i'll not discuss how to do it in these forums
    Robert
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Motherboard won't boot past cmos
you are pretty much right it may be a corrupt bios, however before we come to a conclusion try isolating both Seagate Barracuda 7200 rpm 80gig ide hard drive and optical drive only and then see if it at least goes past the bios screen, if yes then the bios is ok and just needs to be resetted to defaults. dont expect it to load windows even if it goes past bios check as hard disk which helps to boot to windows would be removed. also in case if you are using 2 ram slots try connecting only 1 ram chip in 1 slot and then see if it goes past the bios test screen. do reply with results. Good luck.
Feb 08, 2012 | Abit Computers & Internet
I want to change my boot sequence. But there is no option at bios. I have the laptop of 6500model. Its urgent please help me. it is too urgent
Hi, most HPs or Compaqs or any laptop for that matter, you can access the boot menu by pressing F12, or F10, or F1. You could see it on the screen rigth after you boot the machine, but it goes really quick, so you have to be aware. I hope this helps
Apr 26, 2010 | Compaq 449901-001 - HP Presario V6500...
I have a Acer Ferrari 4006wlmi it boots and
Hi...
You need to reinstall the OS.
Let me know
Thanks
Smith
Aug 09, 2009 | Acer Ferrari 4006WLMi Laptop Notebook
Cant get into anything at boot up
try f 2 to go into the bios and reset boot sequesnce to boot from DVD drive
May 28, 2009 | Eurocom 888es Notebook
It wont boot pass bio screens
have u tried booting into safe mode f8 key or hitting f8 and choosing last best known configaration
Mar 16, 2009 | Eurocom PHANTOM D900T Notebook
My eurocom wont boot pass bio screens
Hi
few possible problems:
The hard drive is not detected or not working
Or the operating system is corrupt or missing
Or the computer is not set to boot from the hard drive.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Change the boot order so its CD ROM, optionally FLoppy drive here if your laptop has one of those, then Hard drive.
save and exit the bios, use the above link to get info on how to work the bios.
Test and see if the computer starts up normally, if not then you need to use the windows installation cd to install windows into the computer again.
if you get any errors or problems on installing windows let me know.
Mar 16, 2009 | Eurocom 888es Notebook
My computer wont boot past Ai lifestyle screen(initial screen)
Boot from windows CD and after all drivers are loaded it will ask you what you want to do
"Install, repair etc" choose Install and then press the R key for repair and follow instructions from there
Feb 02, 2009 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
Eurocom 888es Notebook Logo
284 people viewed this question
Top Eurocom Computers & Internet Experts
David Payne
David Payne
Are you an Eurocom Computer and Internet Expert? Answer questions, earn points and help others
