Question about Kenmore Elite 45986 Front Load Washer
Dark Grease stains on my Kenmore Front Loading washer
The clothes have dark grease stains that stretch out in long lines. I can wash them out by hand. We removed a whole bunch of gunk on the rubber around the door, hoping that would fix the problem, but it still persists. Is wiered, sometimes no issues, and all of a sudden, an etire load is ruined with tons of stains. It seems only the outside clothes that were nearest the metal drum during the spin cycle that get the worst.
Help !
  • rpstark Feb 09, 2009
    We have had the same problem with our Kenmotre Elite. We actually took off the black seal and cleaned out all the "gunk" around the edges and then put it back on. The next few loads were fine but then all of a sudden a whole load of whites was covered in dark streaks.
    This is a picture of one of or destroyed shirts...
5 Suggested Answers
  • 30 Answers
SOURCE: grease spots and stains
Yes you can. Remember a front loader has no gearbox so no oil is coming from there? fabric conditioner, washing powder,and oils from our bodys can build up on the tub walls. All it needs is a good flush out. You can use dishwashing powder. Run it through with no clothes in you washing machine on a hot wash or a wash and hold a couple of times to flush it out. NZL
Posted on Jan 30, 2007
  • 47 Answers
SOURCE: Dark Grease stains on my Kenmore Front Loading washer
THE SEAL IN YOUR TRANSMISSION IS GONE. NEEDS TO BE REPLACED.
Posted on May 13, 2009
  • 176 Answers
SOURCE: grease/dark spots on 'clean' clothes
This is a cronic problem of front loader machines. The two bearings that hold the wash drum are dried out and then they over heat. The heat build up weakens the seal that keeps water in and grease out starts to leak and the problem just becomes worse with every load. A service repair man will charge you the cost of a new machine to fix the unit. You can replace the bearings and seal with parts from a bearing supply store and if you do, only use bearings from Japan or Germany. Your machine came with ones from China and that is why these machines are failing after 4 years.
Posted on May 24, 2009
  • 41 Answers
SOURCE: I am getting stains on my dark clothes that look like oil stains.
Check that the dispenser is clean, it may be gunged up with black gunge, use soda crystals and put machine on hottest wash. If all is clean it could be down to seal gone in drum letting grease into system. Good luck, let me know how it goes.
John
Posted on Sep 03, 2009
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Grease stains on dark clothing
this may due to softener,put spray and wash on stains and let it set all day,stop using softener use HE detergent and oxy clean powder wih soap in dispencer,also you may want to sanitize washer before you wash shirt also use the stain setting and extra rinse.thanks
Jul 29, 2010 | Kenmore Washing Machines
Clothes have dark streaks after washing this is a kenmore front loading washer model number 417.42142100
I read post after post about this very same problem, it is caused by a failure of the bearing that the tub rides on, this causes the grease seal to leak and then the streaks which are grease stains from the rear bearing
Jul 07, 2010 | Kenmore Washing Machines
Dark, grease like stains from washer
the washer tube seal is leaking, u will most likely need to pull the tub replace the seal and the tub bearings
Jan 11, 2010 | Washing Machines
John
Sep 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Mysterious gunge appears ocassionally on clothes
Could be bad bearing, leaking grease.  Open the back and see if grease is oozing from the bearing??
Mar 23, 2009 | Kenmore Washing Machines
Dec 13, 2008 | Washing Machines
Kenmore washer leaves dark streaks on light colored clothes
I suggest you first take a clean, white cloth wetted with a stronger solvent such as 'Oops,' carburator or brake cleaner (with these two, DON"T overspray, they will damage plastic and paint) and wipe the drum inside to make sure there is not some gunk adhering that is gradually depositing itself with each wash cycle.
If you have a shade-tree mechanic in the family, they may have gotten a gob of grease on clothing that transfered to the inside of your machine.
If you don't find enough on the cloth to have caused the problem, I think you have lost a seal on the drum-side of the transmission.
Jul 01, 2008 | Kenmore 43042 Front Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
77 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
