Question about HP Photosmart R927 Digital Camera
Cannot load hp r927disk to hp windows vista
Cannot download hp photosmart r927 dsk to hp windows vista to transfer pictures to laptop
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Posted on Sep 14, 2012
  • 48 Answers
SOURCE: photosmart R927 Digital
Take the card out of the camera, and on the card (I believe its an SD card) there should be a sliding tab on one side of the card. This tab will lock the card (much like a floppy disk or a VHS tape) and prevent it from being wrote too. Slide the tab opposite of the direction it is facing and you should be able to use the camera again as normal.
Posted on Dec 18, 2007
BillB-SA
  • 2761 Answers
SOURCE: My Photosmart R927 will not turn on. I installed
Assuming that the new battery was the correct type and that it was fresh/fully charged, your problem may be due to or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Posted on Oct 13, 2009
drifterK
  • 4924 Answers
SOURCE: HP R927 says that the 4GB card i recently bought wrong format
ok ...see that into the side of the card( if its a SD) has a slide like button with 2 positions ...one of them is the unlocked one ...after that either format it into the camera if it has that feature...or just connect it to the computer and it will be found somewhere into the My computer as a removable drive ....just right click and format in Fat 32...this is the actual storage format fit for this cards..
Posted on Oct 30, 2009
  • 11967 Answers
SOURCE: 4gb memory card in HP Photosmart R927 Camera? Yes or no?
Did you format the card in the camera first?
Posted on Nov 13, 2009
  • 1705 Answers
SOURCE: Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Posted on Apr 26, 2010
My hp photosmart r927 is very slow when processing a picture. what could cause this?
Several things can cause this. 1. Low battery 2. Memory card almost full 3. "cheap" memory card...too slow at writing data 4. Card hasn't been formatted in the camera for a long time. This will erase it so download any pics to your computer first.
Oct 19, 2010 | HP Photosmart R927 Digital Camera
Apr 26, 2010 | HP Photosmart R927 Digital Camera
Does the R927 take panaramic pictures? If not, what cameras do you have that do?
The R927 does indeed have a panorama mode, which lets you take two to five pictures and stitch them together using the supplied software. See page 18 of the manual for more.
Mar 04, 2010 | HP Photosmart R927 Digital Camera
How can i transfer pictures from my hp scanner to my computer?
how can I transfer my photos from my scanner/printer to my windows photo gallary
Sep 18, 2009 | HP Photosmart C4150 All-In-One InkJet...
Every time I try to take a picture with a flash, camera just states "charging flash" but will not take the picture. Camera is a HP photosmart R927
IF your holding down firmly on the button and it just keeps saying that it is charging then you may have a serious problem. This sounds like it is defective. I hope it is still under warranty. If not you may want to consider a new camera. Sorry but no easy solution to that one.
Allen
Sep 11, 2009 | HP Photosmart R927 Digital Camera
When I bought camera I had Windows XP. New computer has Vista.
So you now have Vista, but the software will not load...
If you have Windows Vista (32-bit), click this link and download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1154651&lang=en
If you have Vista 64-bit, use this link. Download the "HP photosmart software and drivers" package. Install by directions.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&product=1154651&lang=en
I hope this helps you, don't forget the "FixYa" rating if this solves your questions!
Apr 03, 2009 | HP Photosmart R725 Digital Camera
Using SD HC Memory Card with HP R927 camera
No. The R927 is limited to SD cards 2GB and smaller.
Aug 25, 2008 | HP Photosmart R927 Digital Camera
HP Photosmart R927 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
