Question about Acer Aspire 5610-4648 Notebook
Orbicam This sopped working for no reason and I too, get the message "camera not found" How do I fix it??
Orbicam has stopped working do I need an upgrade
Posted on Oct 01, 2008
Acer Orbicam is 'unplugged'
First uninstall cam driver from add remove program or device manager.
Then install again.
If you havent cam driver then downlao0d from below link and install.
http://gd.panam.acer.com/home/
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Acer Aspire 5100 Notebook
My orbicam is not working
You should go online and download the updated Driver for the orbicam (google on orbicam). Reinstall it, restart the computer, and then try the cam again. There may be something in Skype that helps config your cam.
Aug 28, 2009 | Acer Aspire 5050-3242 Notebook
Acer Orbicam
just the put the software cd for the orbicam and install it
Jul 23, 2008 | Acer Aspire 5610-4648 Notebook
Acer orbicam
There are two software entities involved – the camera Drivers and the OrbiCam application itself – and BOTH need replacing/updating to fix this problem.
The new driver and a new version of webcam application (below) seem to fix the issue.
The correct files to download are:
Acer Orbicam driver (Bison)
Acer Orbicam Bison utility 1.0.0.13
These can be found here under the MS Windows Vista drop down menu:
http://support.acer-euro.com/drivers/notebook/as_9300.html
In order to fix the problem, you must download and install them both to make the Orbicam work correctly.
FOLLOW THE INSTRUCTIONS BELOW IN THE SAME ORDER:
1. remove the installed OrbiCam application and reboot if required;
2. install the new driver (preferably with the “driver update” wizard from Device Manager)
3. update the Orbicam application 1.0.0.13
After this, the webcam should function properly, even if the original Orbicam icon disappears.
To check everything is working OK run LiveCa07.exe or BisonM07.exe that are located in the c:\windows\bisonxxx\ folder or simply run Messenger
Feb 19, 2008 | Acer Aspire 5101WLMi Notebook
Acer orbicam has stopped working
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
Jan 28, 2008 | Acer Aspire 5100 Notebook
Orbicam unplugged
go to your device maneger in the system properties (by right clicking the My Computer icon and go to properties click the tab Hardware and then go to Device Maneger) check if your cam is working properly and check if its enabled
regarding w/ your USB you can check it there....
lovingly yours
Hellen
Jan 16, 2008 | Acer TravelMate 4230-6499 Notebook
Acer orbicam 5570 model.. some other application might be using it
OK, your problem is not software related. I have visited this page and around 10 others, and done everything to find a solution. Well it has worked for me, and I am taking my laptop to ACER soon as i have found out the problem. Open your Acer Orbicam application and while it says camera not found or whatever grip your camera tight as if trying to close the casing. Twist it both clockwise and anticlockwise and try to nudge it right and left. I believe by carrying it in our backpacks or something the camera messes up with the pressure of other items. That i think is the reason why with their new laptops ACER has discontinued the swivel cam, the new series has fixed cams. So, try this fix and I think it should work becase I had the same problem and it worked. And after that if you still have the warranty go and get it fixed by ACER.
Best of Luck!
Jan 13, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer oribicam not working
you should be able to get the drivers and application from acer.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html
select notebook, aspire 5100, and scroll down to acer orbicam
you will need to go into the control panel, system, device manager, and check under imaging for acer orbicam, double click it and it should tell you the manufacturer (bison, logitech, suyin)
grab the appropriate driver and camera applications
remove the installed orbicam application via add/remove programs and reboot if necessary prior to installing the new drivers and application.
if this doesn't fix the issue, please post a follwup and i will see what i can find out.
hope this helps,
trin
Nov 17, 2007 | Acer Aspire 5100-5033 Notebook
Failed programs
is this a windows error message or it is your webcam software? If this is a windows error message the best ay to fix it is to recover your computer to an earlier date by running the system restore utility in the systems tool folder. if its your webcam software i would uninstall it and re-install it back again. please advice.
Sep 23, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
