Hello I just logged onto your site and one of your graphics displaying several TVs and their problems had my exact TV and its exact problem. Here is the TV and its problem, as copied from the graphic explanation on your site. RCA D52W20 52 in. Rear Projection HDTV-Ready Television Problem: RCA TV tried to power on but nothing....... Solution by: willtab (466 solutions) Hello. You have a Rca d52w20 this is what is known as a itc222 chasis. and i see this set alot at our shop. The first thing that you can do is to unplug and wait 30 min to hour and replug the set in....
  • marcoiafolla Sep 29, 2008
    Hello
    The problem with my TV is that I can literally hear the TV trying to turn on (some clicking noise inside the TV), but after 3 attempts it just stops. After trying several times in a row the TV will eventually turn on and function normally. Once the TV is on for sometime, if I turn it off it can turn back on without problem. Also, I've noticed that the TV can turn on much more easily if it is warm inside the house; it takes much, MUCH longer to turn on if it is cold inside the house.
    Please help!
    Marco
    Hello
    The TV is a RCA D52W20 52 in. Rear Projection HDTV-Ready Television
  • 3,037 Answers
It sounds like your TV may have one or even several defective solder connections that need time to warm up before the TV will work as normal. The connections could be on any one of the circuit boards. For starters check out the convergence board with a X10 magnifier and pay close attention the the connections on the pins of the amp modules on the board.
If you have no electronics experience or experience with power, then I recommend that you get someone who does to check it out for you
Posted on Sep 29, 2008
  • 19,396 Answers
Ciao marco,
The clicking noise is a device called safety protection switch that keeps turning off the TV because an error has been detected.
When a problem, such as a wrong voltage, a short, a defective IC or a bad component is detected, them main chip in your tv, familiarly called the jungle chip, send the unit in what is called protected mode.
In this situation a switch will keep turning TV off to prevent more damage, that is the clicking noise that you hear.
Try unplugging the TV from power for one hour or two, this will drain power completely and reset TV.
If it does not work, then the TV must be inspected following the troubleshooting diagrams from the service manual.
To do it yourself you need experience in testing electronics, some test requires working with live power. If you decide to DIY , get first the service manual.
If you need to call a technician use the phone number printed on the user manual.
You can get service manual and parts here.
Spero che questo possa essere d'aiuto.
Regards
  • 10,594 Answers
What exactly is problem in your tv and what have you been checked.
Let me know to give you further info.
  • Shahid Electronics
    Shahid Electronics Sep 29, 2008
    Alright, its problem of few leaky / weak capacitors in power supply and possibly in horizontal deflection area.
    Please mention exact TV model number to guide you more.
    Sergeant:
  • 399 Answers
Check out this link for the screen problems as you prescribed you have and also diagrams and step by step repair help is given
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
feel free for further queries.
reply.
thanks
Posted on Sep 21, 2008
  • 13,433 Answers
how can we help you?
  • Ekse Sep 21, 2008
    If your tv is not showing any signs of life, possibly a fuse is blown in the power area of the tv.
My Samsung tv model CS - 29M20MH switch onto standby mode with led flashing several times then switch off - no screen coming on
From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Jul 20, 2015 | Samsung Televison & Video
TV won't power on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 06, 2014 | Sony KDL46EX400 46 in. HD-Ready TV
How to log in tv sony
Your problem post need more clarification to post a solution. Please provide more details about the problem you faces with this TV or visit this site and see whether it help you.
Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Some times, the ads attached with each posts might help you to find the availability of spare parts. There are more than 590 posts to different brand TVs.
Aug 17, 2012 | Sony Televison & Video
I have an HPw2216h monitor connected to an HP pavilion tower running windows 7 For the past couple of months the monitor will flash a red hew across the screen and then go away but now it is a continuous...
your problem lie in the electron gun at the back of the CRT. most likely is their is a faulty transistor or resistor that has been devalued/worn out and has to be replaced.
There should be 3 main transistors for the 3 colors - red , green and blue. So most likely the green and blue are acting up so you only have the red that is producing color leaving your screen with a red hue like appearance.
It would be wise to replace the CRT board if you plan on keep using this crt monitor for a longer period as soon their parts will be unavailable to the phasing out of crt monitors.
Good luck and thanx for using Fixya.
G.
Jul 20, 2011 | Panasonic MonitorCRT, Color 20", 500 TVL,...
I have connected my PC to TV via S-video. Pc works fine, but tv displays just the background of my PC screen. Audio works fine. Please help. Thanks
So what exactly is wrong? It seems like you have dual screen enabled. Try mousing beyond the edge of you PC screen, the cursor may move onto the TV. If you don't want dual screen, there's an option for clone display instead.
Jul 15, 2011 | PNY 6200 512 MB AGP DVI + VGA + SVideo...
The tv looks like the old tvs with the contrast controll how do you adjust a projection tv
Exactly as the old TV's. There is three tubes producing the picture and the technology is just the same. If you cannot find your instruction booklet, log onto Sony's web site and download it.
Hope this helps.
Nov 12, 2010 | Sony KP-53XBR200 53" Rear Projection...
How can i make the laptop screen show through my tv
Hello.
Simply hooking up is not enough. What type of cable are you using? HDMI? analog VGA? DVI? S-Video?
* You should also use [Fn] button in combination with [F5], [F8] or another button that shows monitor sign as well (CRT/LCD if it's in written form). Possibly by pressing several times in order to achieve results.
* In some graphical cards (usually in Intel Extreme Graphics) you should locate icon on systray (near the clock) and right click on it, then choose (Graphic Options) -> Ouput to -> Intel (R) Dual Display Clone -> Monitor + Notebook (if you are using VGA cable)
A solution in graphical details can be found here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-58625.html#ie
Sep 16, 2009 | Dell Computers & Internet
Unable to connect my pc to TV
The reason why your TV is showing no input from your laptop is because of the display resolution of your graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs can handle.
I have actually dealt with a no input signal like this before, and this was what I did.
Hope this helps.
Jul 18, 2009 | Dell INSPIRON 600M HARD DRIVE CADDY 6X609...
Philips 42PF9630A Not Working - Red Led Blinks 7 Times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
May 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
Still Not working. no output on tv.
Open the ATI software, go to "set up my display configuration" and from there you should have an option to make the TV mirror your screen exactly. If I misunderstood you and you're attempting to do something different, all the options you need to configure your display should be right within the ATI software.
Apr 06, 2007 | MSI RX300SE-TD128E RADEON X300, (128 MB)...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
Electro Med Services...
