Question about Hitachi 53UWX10B 53" Rear Projection Television
High definition I just hooked up my PlayStation 3 Blue Ray to my Hitachi 53UWX10B 53 in TV and I am having trouble getting a high definition picture. My PlayStation 3 is showing that it is ready to display picture in 1080i but the TV doesn't show up in high definition. Any suggestion on how to get a high definition picture out of this tv?
Have you tried Video input #5?
Posted on Oct 23, 2008
How can i hook up a ps3 to a tv
"These are the optional uses of a Playstation 3, not just playing video games this is a lot cooler. Video connections on a Playstation 3, now this is the back of a standard Playstation 3. I'll show you really quick; we have our power, AV outs, digital audio, LAN for internet, HDMI out so pretty much if you want to get high definition picture quality you're going to have to go out and get yourself a HDMI cable. It will go from HDMI the Playstation 3 to the back of your HDTV, that is your HDMI cable this will carry audio and video in one cable. Of course if you want to go on the internet you have the choice of the wireless if you do buy a wireless, if not you can just plug in your inthernet cable right there. We'll skip the audio for now cause that is the next chapter and we'll go to the EV out, you have two options here if you still want high definition video and you don't have HDMI capabilities on your TV you can still go component. If your TV will allow it, component is the RGB that is your red, blue and green cables so with these cables you can still have a high definition signal broadcast to your TV through this output right here. If you are using the standard TV standard definition you don't have the capabilities of high definition yet it doesn't matter you'll get there. Just go ahead and grab one of the standard cables which is your RCA cables and this will be your yellow, white and red. This of course yellow is for the video, white is for your left audio and red is for your right audio so with these cables you can plug up to any standard TV even a high definition TV but only give you standard definition picture quality. So these are the video connections on a Playstation 3."
Please rate the solution. Thanks for contacting Fixya.
Jul 03, 2010 | Sony Playstation 3 (PS3) Console
Hitachi mdl53uwx10ba
You can get a free manual for your unit at http://www.retrevo.com/support/Hitachi-53UWX10B-TVs-manual/id/371ag905/t/2/ Your unit is not a digital unit in the sense that you could get off air channels in digital. It is digital with the other inputs but not off air. To get digital off air you would need to buy a digital box to convert the signal to analog or separate audio/video or composite video. Cost for a box is about $40.00. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 26, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Will Hitachi 53UWX10B 53 in. Rear ProjectioSupport play station 3
Yes, it will work. Be sure to use input 4 with the 3 rca input cables red/blue/green for video and 2 rca red/white for the sound. You need component video output on the PS3. http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&langId=-1&productId=8198552921665061579&storeId=10151&INT=M:ak is what you need, if you don't have it already. Here's the thing. The PS3 will work on any set. You can hook it up with the yellow wire and red/white wire for standard def. or 480i. The component cables are for 720 and HDMI for 1080. Your set don't have HDMI, it has component input. The service manuel say's it has 720I available. You can see if the front has HDTV sticker..if it does, them for sure it does. Either way, the PS3 will work on your set. I'm 90% sure it's 720i as well.
Dec 24, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B 53 in. Rear Projection Television will it support the play station 3 is it 720p?
Check your TV back panel. If it has a DVI connector (like your monitor), you can get a HDMI to DVI cable and it will support both 1080i and 720p. My 57XWX20B has this connector. Good luck.
PROBLEM WITH GETTING LOCAL hd CHANNELS
You need to have a set top box.
By law, as of March 1, 2007, almost all televisions should include a built-in tuner (called HDTV, digital, or ATSC tuners) that can receive high-definition programs over the air by simply connecting an antenna. Your HDTV doesn't have such a tuner, you'll need to connect an external tuner (or cable or satellite box) to watch high-definition programming. External over-the-air HDTV tuners currently cost at least $150.
Nov 14, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blue circle across top of tv screen & maybe some yellow
Good Day,
Does the blue spot have tin white lines?? Is there a picture behind the 'circle'? You may a blue crt (tube) problem.
Jun 06, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Blue color doesnt muve up
hi there. sounds like a bad convergence IC. possibly a broken connection(s), parts are located on a large heatsink near the center of the main chassis, part number is STK391-110 for standard definition and STK391-570 for high definition, the location and part numbers can vary from model to model and year to year. hope this helps.good luck and be safe.
May 26, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Bad picture on a Hitachi 53"
The problem is in the vertical sweep ckt. and is heat related. Would need to be repaired by a tech.
Electrode
Feb 28, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Picture Problems with Hitachi 53" Projection TV
most tv shop's will replace convergence ic's,which your tv needs.Thepart number is stk392-180 very common You need 2 plus poss resistors,3 bucks apiece
Mar 20, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
120 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
