Question about Dell 1700n Laser Printer
Dell Laser Printer model 1700
My printer doesn't seem to be able to catch the paper out of the tray and run it through the printer. I can see that the document is in line to be printed when i open the printer page, and it makes a noise like it is trying to print, and the wheels in the top that would push the paper out of the printer in to the recieving bin spin, but no paper goes through the printer.
Thanks.
  • 5 more comments
  • Ewilson1985 Oct 11, 2008
    I am having the same problem. The arm does not come down to catch the paper. I can hear the solenoid clicking but still no arm.
  • tarvyd Oct 21, 2008
    If I open the paper tray, and feed the paper in a little, sometimes it works. Any ideas on how to solve the problem?
  • jburnsidemd Nov 12, 2008
    Same exact problem. Paper not picking up.
  • AdminPhi1111 Nov 18, 2008
    I am having the same problem, our office has 12 of these computers and now 4 of them won't feed...Does anyone know if this is covered under a warranty?
    I am getting the feeling that it isn't just me with this problem...
  • herfdonnert Dec 24, 2008
    same problem no feed no print...
  • Anonymous Feb 20, 2009
    Fwayne
    I have the same problem, but I do not understand how to get the rollers out. Do I have to take the unit apart or is there an easier way? Thanks
  • Anonymous Apr 08, 2009
    My six year old Dell laser printer 1700 would not completely pick up the paper and feed it through the printer. The printer would then report a paper jam. The post suggested simply flipping the rollers (plastic) inside-out. That seems to fix the problem. I hope I get another 7 years out of the printer.
    Scholar:
  • 97 Answers
Its caused by the rubber on the feeder wheels getting worn. And the fix is easy. Just peel the flat rubber rings off the rollers, flip them inside-out, and put them back on. Now your paper will feed all the way intot he machine. ( you can order replacements the next time)
Other: Dont use alcohol on these rubber parts, it only dries them out and makes it worse, you can wash them in soapy water though.
Use higher grade heavier paper, its a bit more expesnive but wont wear out your printer with jams and dust.
Most folks (including myself) think the rollers are actuated when printing, actually the paper tray causes the rollers to pop down onto the paper stack when you close the tray all the way. you cant see it, its like trying to watch the refrigerator light go off when you close the door! :)
Posted on Dec 23, 2008
Quick Fix: It seems that many people have the same probelm, that the paper is not being picked up. I've heard that flipping the rubber on the wheels helps but not if the "pick-up arm" isn't coming down to the paper level. And yes, there is a safety switch on the right side that prevents the arm from dropping on the righ hand side and is activated when the paper tray is in. But. Here is the quick fix to get the pickup arm down. Remove the paper tray. Flip unit upright. Look at the pick arm assembly. There are two springs pulling tension up on the pickup arm, one in the centre and one to the left, keeping the arm in the up position until the gear mechanism activates the swing arm. Gently and carefully remove the shorter/stronger spring on the left hand side. This will releive the tension and the arm will drop onto the paper. Carefull when putting the papertray back in since the arm is now down, lift with fingers until the tray is almost completely in. Just one spring and your on your way again. It worked for me, without spending $150 for service and/or taking the whole unit apart, too many gears to worry about. Good luck.
Posted on Mar 12, 2009
I had the same paper tray feeding problem with my Dell 1700 laser printer. The printer sounded as if it should print but the paper tray arm did not come down to pick up paper. It made noises as if it would work but no paper feed into the printer
First I checked that the printer would print manually by inserting paper into the manual slot " or envelop slot as some call it ) It printer fine. I could not find any jams, stuck wheels , gears etc.
I decided to take the unit apart but cautiously.I remove the side snap on panel ( this side has the button to open the front for paper jams , etc.) I think you have to remove 2 screws as well to get the panel off
Put the unit on its side look for gear jams etc.
Unscrewed the cover and moved gears manually, I then moved all gears manually but carefully
One gear turns the wheels on the paper arm. ( check that these wheels turn and that the tires are in good condition if not turn them inside out )
A drop of lub spray here & there. I did not want to totally disassemble the gear assemplies as it look too complicated to put back together.
I put all back together ( with no excess screws ( lol) and voila the printer worked first time.
Why exactly the paper arm would not come down I don't know but one gear must have been out of alignment
Good luck - proceed slowly & cautiously but you will have nomprop butting back together
Posted on Dec 02, 2008
I'm having the same problem. The arm with the wheels will not drop down. any suggestions?
thanks
Posted on Oct 10, 2008
Dell laser printer MFP 1125 paper tray removal
I just did this 5 min ago. The tabs that hold it on the machine have cams that hold it in. just squeeze the tray lightly at the tabs and it slides right out.
May 31, 2009 | Dell 1125 All-In-One Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Dell 1700 only printing to envelope feeder
make sure that the manual feed tray is not set as default make sure you main tray is
Apr 30, 2009 | Dell 1700 Laser Printer
Does not pick up paper from the tray
How much paper gone throught the printer since it is new?
usually the pickup roller is good for 10,000-15,000 sheets.(20x500 sheet pack). if the printer went throught that much paper, then the pick up roller need to be replaced.
if not, make sure there nothing stucked on the pickup roller, and the roller is not shining (it need to be soft and rough).
Apr 18, 2009 | Dell 1700 Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell 1700 printer will not print
Hi albrecht,
i think u might have used ur printer without paper often . unplug the printer from system and switch it off.Replug it again on the system ant switch it on and see. Even then if it is not printing uninstall the drivers for printers and reinstall again and print.
Mar 04, 2009 | Dell 1700 Laser Printer
Printer problem -Dell Laser printer model 1700.
make sure the side guides in your paper tray are tight against the paper.
Dec 19, 2008 | Dell 1700n Laser Printer
I have a dell 1700 laser load paper lite and ont print from tray
sure..it's in the printer control panel, under paper source. Open that up, and you'l lmost likely find that it's on a default. Also, do a print test page under admin, prior to doing any print jobs.
http://www.kauaikeepsakes.com/computerguy/
has an option for a Free demo of a Shared Screen session.
Jan 24, 2008 | Dell 1700 Laser Printer
Dell 1700n Laser Printer Logo
581 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
