Nokia C5 Cell Phone Logo
Anonymous Posted on Oct 05, 2011
How to copy or take backup all contacts from phone memory to memory card in nokia c5 mobile. plzzz tell me the solution for this problem...
Anonymous
Level 3:
President:
  • Master 943 Answers
  • Posted on Oct 05, 2011
Anonymous
Master
Level 3:
President:
Answers
943
Questions
Helped
152638
Points
2929
Go to settings->sync and backup->create backup->select contacts and press done it will automatically backup to memory card..
Anonymous
Level 2:
Sniper:
  • Expert 102 Answers
  • Posted on Nov 09, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
102
Questions
0
Helped
30376
Points
216
Or open contacts, options, mark all, options again, copy marked, copy to sim card or memory card. copying to memory card is better than sim becuase sim memory is limited amd may not accomodate too long names.
Want to reterieve contacts from phone memory
If you didn't get a backup then no luck to retrieve unless you pay $$$$ to acknowledged techie.
I forgot password of memory card of nokia c200 .... I formatted it but it doesn't work can u help me to solve this problem..??
Please format the memory card so:
Delete some unnecessary files in your phone memory like images and videos. Go to your phone gallery and delete some of those. And if you want to use the memory card as phone message storage then go to Messaging - Option - Settings - Other and then Memory in Use, select your memory card.
But if your phone is infected with a virus then you need to format your phone. One sign of infection is your phone keep sending a message randomly from your contacts without your consent.
Use these code and enter it to format your phone:
*#7370# and then the default code is 12345
Take note: Make sure you back-up your contacts or any other important inside your phone.
Hope I make it clear and does makes sense
How to do BACKUP
  1. Open Contacts application.
  2. Select Options > Settings > Contacts to display and enable SIM memory (uncheck other alternatives) > OK > Back.
  3. Select Options > Mark/Unmark > Mark (or Mark all).
  4. Select Options > Copy (or Manage > Copy).
  5. Select Options > Settings > Contacts to display and enable memories you want to use.
1helpful
Nokia C5 power off, hangs frequently, no sound sometimes
These problems usually occur in most Symbian based phones due to malware attacks.The only practical solution is to restore and clean up your phone memory as soon as possible.Please follow the instructions below to clean up your phone memory.
1.Before cleaning your phone memory backup your Contacts to your memory card or SIM card (You can mark and copy contacts to SIM card directory ).
2.Enter *#7370# on your phone
3.You will be asked to restore the factory settings.Press YES.
4.Phone will restart with the default factory settings and the unwanted files and other malwares will be deleted from your phone memory automatically.You can change the default settings of your phone accordingly.
5.Restore the contacts from your memory card or SIM card.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
I want to delete my phn memory n want to create a back up on memory card...and i want my phone memory totally free... Plz tell me what to do?
first take aback up of your contacts in a sim card(go to contacts then select all contacts then on the options copy all to sim). then copy the images and other sounds into the memory card now go to settings then go to restore factory settings then click restore all.
My nokia n70 has some problem,fristly the with screen appers then i swith off the phone then after some time i again swith on the mobile but mobile dostnot swith on why
go to settings / restore factory settings /restore original or reset all when u reset the phone your memory card must be removed from the phone otherwise you lost all the data in memory card and you must copy your contacts and messages from phone to memory card. you can copy them to PC yousing PC sute or you can creat a backup in the phone and copy to memory card.thanks
There r some ringing rones,some songs in my memory card,wen i play them it says not enough memory ,cel is nokia 5130 exprsmusic,plzzz plzzz plzzz help
restore ur phone to factory default its easy u can press menu , setting and last option is restore fac. def. ok then two options settings only or restore all use restore all keep remember that ur phone memory will deleted so first backup ur contacts ok
My phone memory is protected
I would like to advice you that, Remove all of your passwords from memory cards & phone memory.
Make backup file by nokia PC Suite, Its the best option to keep backup of our mobile.
Thanks.
Nokia N73 memory full, backup help
To make backup of your contacts
  1. you can backup your contacts by saving them in sim memory. Go to your contacts mark all of them then copy to sim directory. if you have contacts more then your sim capacity use more then one sim.
  2. You can backup them by using PC Suit.
  3. you can send all of your contact details to your computer by bluetooth. This is a long process but most effective. To do that you have to send your contacts as business card format through bluetooth.
To make backup of your messages
  • Open messaging then go to settings, choose Others (It appear in last).
  • Cahnge memory in use to your memory card.
  • Remove your memory card from Mobile & put it in Computer.
  • there is a folder named system (It is a hidden folder so choose the 'view hidden files & folders' option through folder option in your computer).
  • Inside the system folder there is a folder named Mail copy this to your computer.
  • After formating your mobile repeat whole process but this time you have to replace the Mail folder by the folder saved in your computer.
Contacts problem
Use Contact Manager or Backup Contacts Mobile Software :
If not Done Transfer to Memory Card in Others Folder
And Then In Contacts copy From Memory Card:
if Not Done Use Another Phone Manager Software For Mobiel.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
