Question about Samsung VP-D361 Mini DV Digital Camcorder
Eject error R
My problem isnt with ejecting.
the tape i have been recording is at its end, and so it says eject R, and wont let me rewind the tape to view it, the manual says to eject tape, take battery on n off, so iv done that, doesnt solve it, yet if i put a new tape in, it records, plays, rewinds as it should.
so it is just one tape, that was workin right up until it came to its end, that wont do anything, anyone know why?
  • Samsung Master
  • 5,412 Answers
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Posted on Jul 11, 2017
SOURCE: Problem with my camcorder
i need repair my dvc on off swich
Posted on Jul 25, 2007
  • 11 Answers
SOURCE: Eject light comes on after I start playing the tape
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Posted on Jan 08, 2008
  • 73 Answers
SOURCE: Entire camera is locked up
Posted on Mar 02, 2008
  • 107 Answers
SOURCE: Samsung mini DV sc-D366 always displays eject
I believe your problem is in the drum motor assembly part No is AD97-10579A. Samsung they know that problem it require a Technician to replace this part because you must adjust electronic and sometime mechnism as well. Depend which country you are it might cover under warranty even your CAM is out of warranty just check with Samsung in your area
Posted on Dec 04, 2008
  • 56 Answers
SOURCE: The eject symbol with an R shows when I insert a
if R symbol appeared on your camcorder, it means that there's a mechanical fault in it. try soft reset on the camcorder by removing the battery and then insert it back again after one minute.
Posted on Jun 30, 2009
Vcr ejects after 10 seconds
The tape is wound tight or is not wound evenly creating friction. There is a safety feature designed into the vcr that senses that there is too much tension. Fast forward all the way then rewind all the way. This is the way it was in the 70's 80's for cassette tapes and vhs tapes. If the tape still ejects then check the belts.
Dec 01, 2013 | Toshiba DVR620 DVD Recorder/VCR
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Mar 08, 2010 | Sony Televison & Video
Canon hi-8 camcorder will not playback recordings. full battery. ejects tape during playback
It sounds like the tape isn't turning and the player thinks it's to the end of the tape and ejecting it.Perhaps when you rewind its drawing the tape up so tight the sensor thinks it's at the end.Take the tape out and see if you can turn it by hand to release the tension.There's got to be some form of release mechanism to let the tape free wheel.Once loose I'll bet it will playback just fine.
Jan 18, 2010 | Cameras
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
I have a Sylvania 6240VE vcr. When I try to rewind a recorded tape, the vcr ejects the video. I was wanting to purchase a dvd/vcr combo, but the reviews for these items are awful. I tried a Magnavox combo....
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Tape will not eject
If you open the eject thingy like normal then look for a small white plastic tap. its located right underneath the "start/stop" text you see on the back end of the camera (where the record-button is). You´ll need something like a small screwdriver or similar. Press it and and the tape ejects like normal. Worked for me. Saved me the repair bill :)
Jul 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
TRV25 error C:31:22
try hitting it on the side kinda firm.
Feb 25, 2008 | Sony Handycam DCR-TRV25 Mini DV Digital...
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Samsung VP-D361 Mini DV Digital Camcorder Logo
78 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
