LG 26LZ50 LCD TV
Won't turn on. Power LED switches between green and red. Loudspeakers make a tiny pop, so power is getting through, but then cutting The screen is blank.
Any clues ??
  • 346 Answers
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
change the power regulator
Posted on Nov 01, 2007
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
freetek
  • 5568 Answers
SOURCE: tv will not power up
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself but it will likely have the same problem eventually unless they have altered the design.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Posted on Mar 30, 2009
  • 187 Answers
SOURCE: rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
SOURCE: cello l2232af power supply fault, when switching
I had this same problem with my 23" cello TV. It was a problem with the internal power supply - specifically the 12V output. It had fallen to 5V. I noticed that the three electrolytic capacitors (EC7 EC8 & EC9) had bulging tops as though they had been damaged. I replaced these and my TV is now working again although I don't know how long it will last. The three capacitors were 1000uf 16V types. I replaced them with 35V versions (which are physically bigger and a tight squeeze). Your TV repair shop should be able to replace these faulty components in under an hour.
Posted on Dec 19, 2009
LG 17LX1R flashing red LED - TV won't power up
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | LG 17LX1R 17 in. HD-Ready LCD Television
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Proscan 42LA45H 42 in. LCD TV won't turn on, no red led when plugged
The power supply is the most likliest cause of the issue. You can get replacement power supply from www.tvcircuitboards.com
Mar 02, 2012 | Proscan 42LA45H 42 in. LCD TV
When I turn the tv on, the green power light comes on and then immediately turns off, (light goes red). No image or anything comes up on the screen. Never had any problems before this. Checked all plugins....
Use the remote to switch problem,if it's not works,I am sure the power board problem
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | LG MU-42PM11 47 in. EDTV-Ready Plasma...
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
