Question about Uniden Lands Phones
Have static on both phones and need to know to change the phone channel to move static.
I have a DECT 6.0 Uniden answerphone with several handsets which suddenly began making a strange static noise. I am using VOIP cable with the Uniden answerphone being near to the cable phone modem.
I moved the answerphone base and plugged the electric connection into a different electric socket and the buzzing static stopped immediately on the answerphone base as well as on all the handsets.
I gathered that info from another post here on this great website and wanted to post the fix over here to maybe save someone the trouble of going and buying and installing a filter at the phone jack.
I had already called my cable company to come out here and fix the problem and the technician told me to buy another phone because someone here in my apartment complex was using the same frequency that my phone was using. The tech assured me he had four years experience. I found the solution in five minutes online. Ain't technology GRAND???
Posted on Feb 13, 2014
I had the same problem with my uniden 5.8 ghz phone. After placing a filter (from the phone company) into the wall jack and plugging the phone into that filter the static noise was eliminated completely. Hope this helps.
Sincerely,
Paul
Posted on Aug 31, 2009
2 Suggested Answers
SOURCE: Static
When I have a static problem with a phone or radio it usually happens when I have them plugged into a extension cord. Or they are too close to one another. You may try an ext.cord. just having the phone plugged in or find out why you have so many magnetic fields in your house and if moving the phone around to different outlets help.If not I suggest you call Radio Shack. You can not beat their customer service.
Posted on Feb 21, 2008
HOW DO I CHANGE THE BROADCAST CHANNEL, GETTING LOTS OF STATIC AND INTERFERANCE
The broadcast channel can't be changed according to the units instructions some other electronic device is causing the interference you may have to move the base unit. A PDF file of instructions are here
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCgQFjAB&url=http%3A%2F%2Fservice.us.panasonic.com%2FOPERMANPDF%2FKXTG1032.pdf&ei=Jl_aVNSkGobAggTGlYHoBg&usg=AFQjCNEKuKWxZUBDTtUXNDQOW8Mn92B2dw&sig2=oBfK0fI1HOBEHWvabQGLpA
Jan 26, 2015 | Panasonic KX-TG1033S Cordless Phone
Vtech cordless static
The control is usually a sliding switch in the base station, not on the handset. Open the battery holder and look in there,
Dec 20, 2013 | Vtech DECT 6.0 Digital Cordless Phone
Have 3 handsets and all have static or sounds like a fly in the phone, dont have the manuel and dont know how to change channels?
Try turning the plug over in the outlet (at the wall). Are there anyu flourescent fixtures in the area? Move the phone away if possible.
thanks
a
Dec 11, 2009 | Uniden Cordless Phone
I have EL 42108 cordless phone and ans machine with call waiting. when using it stars to hVE STATIC AND FINNALLY SO MUCH CANNOT HEAR OR TALK. HAVE TO HANG UP PUT ON BASE AND WAIT AWHILE ALL THE HONES...
Couple things can cause this. First make sure that your phone line is clean, test it with an analog line. Then check for EMI and other radio interference by moving the wireless station as close to the base station as possible, if the problem goes away you know it is either your antennae or local interference. Next you can try changing the channel your broadcasting on, either the menu system should allow you to choose a channel or it'll be a switch somewhere on the unit. Finally, make sure that the speaker is not damaged or blown.
Dec 03, 2009 | AT&T 1717 Digital Answering Machine
I have static thru the handsets... i see in the
Move it away from other electronics, TV's microwave ovens, etc. Try it in a different part of the house to see if the static is location sensitive. It must be getting interference from someplace. The manual should describe a procedure for changing channels although that may not solve the problem unless the "static" is an interfering RF signal. If this is a remote handset problem, it may be too far from the base or the signal is obstructed by something. 5.8GHz does not have the range of the lower frequency phones.
Nov 14, 2009 | Panasonic KX-TG6071M Cordless Phone
I am having major static on both hand sets. I have reported to the phone company. This has just started to happen in the last 2 weeks. I have nothing new electronically. My land phone plugged in is not...
It is possible one of your neighbors purchased a similar phone and you are on the same channel.
Check your instructions and see if you change the channel.
I hope this helps.
Jul 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Static
Jan 24, 2008 | GE 25952 Cordless Phone
Static on line after DSL installation
I had the same issue - DSL company told me to remove the filters. It worked.
Jan 22, 2008 | GE 25951EE2 Phone
RCA H5400 Cordless phone
Lots of static when I turn it on. Changing the channels does not work. Having no onother appliance plugged into the outlet doesn't work. Moving it away from other appliances doesn't work. What should I do?
Dec 22, 2007 | Panasonic KX-TG1033S Cordless Phone
Static
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Lands Phones Logo
1,025 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
