Question about Jabra BT8010 Wireless Headset
JABRA VBT185Z IS REJECTING ALL CALLS, NOT ON MENU LIST AFTER A MONTH OF WORKING WELL, NOW WHEN I PUSH THE LIGHTED BUTTON TO ANSWER A CALL IT REJECTS THE CALL AND THE CALLER GOES TO MY VOICEMAIL. IF I OPEN MY PHONE WHEN A CALL COMES IN IT WILL CONNECT TO THE CALL. IF I DIAL OUT ON MY PHONE MY HEADSET WILL WORK ANY IDEAS
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
charles0285
  • 160 Answers
SOURCE: bluetooth syncing
Usually to solve some pairing problems shut off bluetooth completely(no lights) Push and hold button until bluetooth comes on,flashes then steady light,you may have to hold button for ten seconds or more.Then put phone in pairing mode.
When asked for pass code enter 0000.Phone should show connected to bluetooth device.
Posted on May 10, 2008
PyroPCMan
  • 405 Answers
SOURCE: don't know passkey for jabra vbt185z
Good Day,
Passcode is "0000"
Hope this helps
Posted on Jul 05, 2008
SOURCE: Cannot Get Jabra BT150 into Pairing Mode
I had problem with my bluetooth not getting into pairing mode,and Now it working good.
Thank you for your best solution.
Posted on Nov 17, 2008
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
Remove number reject list
if you go into contacts, on your rejected contact and press the menu button you will see there "remove from reject list" 18c5bebe-6f9e-4d2d-ac43-b8fc106b69e2.png
Jan 28, 2014 | Samsung F480 Cell Phone
How to block messages and calls samsung corby
Reject list for Samsung:
To Reject Calls:
Recent calls
All calls
Options
Reject list
To Reject Text Messaging
Menu
Messaging
Messaging settings
Text messages
Block number
source:yahoo answers
Aug 18, 2010 | Car Audio & Video
My Rugby allowed me to reject a # I did by accedent. Now I can now undelete it. The step in the directions is not in the phone. Model SGH-A837. Any HELP..
Fixed at AT&T store. Wow some one who knew what they were doing!!
Menu, Settings, Calls(5), General(1), Auto Reject(2), Reject List, Edit, Go to # rejected, Push Uncheck, Options, Save, Exit out!
jw8107 had what the manual said. Compleatly wrong.
Jul 19, 2010 | Samsung Rugby SGH-a837 Cell Phone
How to remove the name from the rejected list
Go to
1)menu
2)select settings
3)application settings
4)select call
5)select all calls
6)select auto rejec
7)in the reject list untick the number you dont want to reject and then press save
it will be saved and the number will not be rejected
May 29, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I am unable to remove contact numbers from call reject list, of a samsung c3053 mobile. In my call log menu there appears ''add to call reject list''. But in nowhere I have found the call reject list. In...
Go to Menu,
Salect Application Setting,
Salect Call,
Salect All Call,
Salect Auto Reject,
Salect Auto Reject On Or Off,
Remove Perticulers Number From Remove List,
Salect Reject List
U see Reject List
Jan 02, 2010 | Cell Phones
How do I get into my reject list to remove people. I've added someone into my reject list by mistake now can't remove them.
Press the MENU button - go to Address Book - go to Reject List Select the name you want to "un-reject" (want to receive calls from now) choose "delete" then "selected"
This will allow you to receive calls from them again. You are deleting them from your reject list.
Jul 17, 2009 | Samsung S7350 Ultra SLIDE Cell Phone
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Jun 18, 2008 | Samsung Cell Phones
Jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Dec 29, 2007 | Nokia 1600 Cellular Phone
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Jabra bt160
hold the button down for a long time
Apr 17, 2007 | Jabra COMMUNICATIONS BT160 Bluetooth...
Jabra BT8010 Wireless Headset Logo
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
