Question about Brother MFC-640CW All-In-One InkJet Printer
I can't scan or do copies because it says no ink and no cartridge even I
just put a new black ink.
  • Anonymous Dec 19, 2008
    I changed all the ink cartiges and it keeps saying the ink is low in all colors. But it does print.
  • Anonymous Jan 06, 2009
    Same with my Brother MFC I've now put 3 brand new cartridges in but the machine won't detect any of them just stating no cartridge. I'm trying to put Magenta in.
  • 4 Answers
There is a Firmware UpDate V 2.4.0 at this address
It address the problem of near empty cartriges even though you have replaced the cartrige.
Posted on Feb 14, 2009
Hp Designjet 500 not recognising ink cartridges. the ink carts were nowhere near empty but coming but the printer says replace bought new ones and put them in and the machine is not recognising them...
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Jul 15, 2010 | HP DesignJet 500 InkJet Printer
Tells me ink needs replaced even after putting in new ink.
check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
May 16, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
How do you change the black cartridge in the printer epson stylus nx115
Here is the Link showing instructions below. If you find this helpful, pls rate me.
Replace Ink Cartridges
Your Epson Stylus NX110 Series and its software will let you know when an ink cartridge is low or expended.
If ink is low, the ink light flashes. You can continue printing until a cartridge needs replacement.
If a cartridge is expended, the ink light stays on. You must replace the cartridge to be able to print.
Keep ink cartridges out of the reach of children and do not drink the ink.
If you need to change a cartridge before it or any other cartridges are low or expended, run the Ink Cartridge Replacement utility.
You cannot print or copy when an ink cartridge is expended even if the other cartridges are not expended. Replace any expended cartridges before printing or copying.
Leave your old cartridges in the Epson Stylus NX110 Series until you are ready to
replace them to prevent the print head nozzles from drying out.
When an installed ink cartridge is more than six months old, you may need to replace it if your printouts do not look their best, even after cleaning and aligning the print head.
Follow the instructions in these sections to check and replace your ink cartridges:
Check Cartridge Status
Purchase Epson Cartridges
Replace Cartridges Using a Printer Software Utility
Remove and Install Cartridges
pls rate me. Thanks and Good Luck...
Jan 23, 2010 | Epson Stylus NX115 All-In-One InkJet...
It will not print in black ink even though I put a new black ink cartridge into the machine
Hello sir, good day, If you cannot print black ink on paper even with new cartridge on the machine, the cradle is dirty, the thing that holds your ink cartridge.
The ink flow is from the cartridge to the cradle then to paper, check the cradle, for proper cleaning.
Nov 13, 2009 | Computers & Internet
Kodak 5300 shows "color ink cartridge needs replacing",even with new cartridge,and new printhead..Ink level display shows color cartridge empty,and its brand new..
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Sep 23, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Even though I have install the ink cartride
Hi there please try this.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
"E", doesnt print scan or copy
Ink has dried inside the printer.
Assuming the printhead is seperate from the cartridge, i would inject JR Inkjet flush into the old cartridge and put it back into the printer. Leave it to stand for an hour or two, then run several cleaning cycles.
Once the ink comes through (if it does) replace your new cartridge and clean again until the print quality is restored.
If this does not work. Then i expect a new printhead is required. (i would try the first suggestion repeatedly).
Ink cartridges should be replaced immediately if possible. and even if u need our technician support contact us at
Jun 22, 2009 | HP PSC 1315 All-In-One InkJet Printer
Ink cartridge
The real problem is that the waste ink tank is nearly full
Correct code procedure for resetting the Canon MP370
Reset Waste Ink
By pressing the black button
with the star (in a
head ?) above it, followed by
scan, copy, scan
2) Select TEST MODE (press right
arrow button 13 times).
3) Select [8] PRINTER TEST
4) It'll now say "- 8-2 +" press
the right arrow key once
to get "- 8-3 +" Hit ok.
5) Select 0. [INK COUNT].
6) Press the ok key.
7) It should return to showing
the "8:
Printer Test - 8-3 +"
8) Press the [Stop/Reset]key -
black key with triangle and
circle on it –
(returning to the state of 3)),
and then press the [ON/OFF]
Good Luck and don't blame me if it
goes wrong !!!!
Now you can print again, but it has not solved your full ink-tank, that has to be solved in future.
Jul 08, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls
Feb 16, 2008 | HP Photosmart C3150 Printer
Ink levels are not responding.
Did you buy a brand new or remanufactured/refilled cartridge? Some cartridges will show empty, even when full.
They want you to buy brand new, brand name ink!
Jan 05, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother MFC-640CW All-In-One InkJet Printer Logo
186 people viewed this question
James Cagle
James Cagle
Jim Keysor
