Toshiba D-410ku DVD REcorder purchased never been able to set it up to work
4 Suggested Answers
dvdcdlaser
  • 1285 Answers
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Posted on Jun 25, 2009
  • 6 Answers
SOURCE: purchased astar dvr-2100 dvd recorder. power button
Can you be more specific? Is there anything on the display? Or is the red power light on or off? Some more detail is needed.
Posted on Dec 23, 2009
Testimonial: "no power at all. unit does not respond. power lite does not come on."
How to play a dvd on toshiba hdd xs32
You must use the input setting and select dvd. Thanks.
Aug 22, 2014 | Toshiba RD-XS32 DVD Recorder
I have a toshiba rdxv60kb dvd recorder,,and can;t tune the programes into my sky box.
I have a toshiba Hdd & DVD / Video Recorder However I can not get it to work with my Sky setr up If I set thimer recording it does not work when I turn it on it will only work pn channels that are not from sky it will not instant record nor will it record programmes prerecoreded of sky HDD it will record everthing other than what I want.
My E-Mail Addres Is fj.gadkey_1@sky .com
My Home hone is uk 01527 545284
Nov 08, 2010 | Toshiba DVR660 DVD Recorder/VCR
How can i connect my toshiba rdxv59dtkb2 to freesat
be more specific please. Normally you could use A/V cables to your dvd recorder then from dvd recorder to TV.
from your signal that feeds to your tv just feed to the toshiba dvd recorder, then from dvd recorder to tv, then you should be golden. Just dont forget to set the channel on the dvd recorder.
Sep 17, 2010 | Toshiba D-VR3 DVD Recorder/VCR
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
When I turn my Toshiba D-VR4 recorder on, it won't go to DVD
I figured it out with absolutely no help from the manual. To initiate recording, you have to press the timer/set button. After the DVD recorder finishes recording, you have to re-press the timer/set button to take it out of recording mode. I think their book needs to explain that more clearly.
Sep 29, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
HELP
I am trying to set the timer record to channel 185, but my unit will only allow me to set to channel 125.
Apr 15, 2008 | Toshiba DR550 DVD Recorder
Auto Chapter Not Working
You might want to visit here http://www.amazon.com/Toshiba-D-R4-Multi-Drive-DVD-Recorder/dp/B0007UVYOY
Sep 13, 2007 | Toshiba DR4 DVD Recorder
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
