Lexmark 4431-w12 Sounds like I am similar to your problem. Paper starts to feed then stalls. I went looking for a manual and istallation service manual with no luck? Ideas? johnatl@yahoo.com
5 Suggested Answers
SOURCE: Looking for a Lexmark Optra T640 Service manual ??
Try this link http://www.smartech-csi.com/portal/service/manuals/lexmark/lexmark-t640-t642-t644-4061-xx0-manual
Posted on Mar 29, 2008
SOURCE: Brother MFC-8840 D paper on manual feed jammed!
i want printer driver for winxp
Posted on Apr 14, 2008
SOURCE: Lexmark x5470 paper not feeding properly
Clean the feed wheels by cleaning with a damp paper or cloth towel. It is kind of hard to get to unless you can take off the back cover. You might try a long handled "Q tip" like the Drs. office has.
Posted on Jun 23, 2008
SOURCE: lexmark t640 noise
Lexmark says that this is a feature called Envelope Enhance. Two rollers 'thump' to remove air pockets in the envelopes to prevent creasing and wrinkling. The "feature" can be turned off in the Paper Menu.
Posted on Jul 01, 2008
  • 684 Answers
SOURCE: Lexmark x4270 wont feed paper
In this Case take out the Paper from the Paper Feed Tray........ Unplug the Power Supply from the Printer.......... Remove both the Cartridges from the Printer.......... Now take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printer and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer...... It should resolve the Issue......... Good Luck..........
Posted on Jan 19, 2009
Printer does not load paper
Hi Good day!!!
paper feeding in crooked or at an angle problem, is common to most printers. HERE'S SOME GENERAL INFO THAT MIGHT HELP: It's possible that the paper may be running into a foreign object and not feeding in at all. A foreign object could also cause the paper to stall, or even feed-in crooked. Remove all the paper and use a flashlight to look carefully into the paper feed-in area. Look for a pen, pencil, push pin, paper clip, candy, etc. If you can't see anything, then actually pick your printer up and turn it so the paper opening is facing down and shake it a little, side to side. Your trying to dislodge anything that might be stuck in the paper entrance area. If nothing falls out, then turn it back over and use the flashlight to once again look inside that area. Sometimes you'll see an object that may have moved over into view while you were shaking the printer. Any foreign object might block the paper from actually being able to move forward, so then the printer thinks there is no paper installed. You may have to even remove the Top Cover to be able to get a better view of that paper feed area. Unfortunately, just removing that cover is not always that easy, especially on the newer printers. You may need a Service Manual for reference, disassemble and troubleshooting. I have not checked, but you can normally find Service Manuals for most printers, at www.2manuals.com (most Service Manuals can usually be downloaded for around $10 +/- ). Even if there is not a foreign object stuck in that area, with the top cover off, you might just possibly see what the problem is and even be able to correct
Thank you for using FixYa
Please accept if my solution helps you
Nov 10, 2010 | Lexmark X3470 All-In-One InkJet Printer
Feed system Problem Lexmark x73
More possible for printer not feeding is paper jump, and stock up jump sensor, look hook type near roller sensor mechanism if still free in move, or if dirt, then try to feed paper manually and look for any obstruction.
Mar 21, 2010 | Lexmark X73 All-In-One InkJet Printer
Lexmark c720 color laser printer
please chack it feed claught unite
thanks
Jul 30, 2009 | Lexmark C720 Laser Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Lexmark z715 problem w/printing
Good luck...
Nov 10, 2008 | Lexmark Z715 InkJet Printer
Lexmark X4850 paper jam
May 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Feeds paper crooked
Lexmark printers are hyper sensitive to dust..It might be causing this problem...Take a cotton swab dip it in alcohol and press it against the roller whilw pressing the paper feed button....
If this doesn't work you should try a longer procedure...Remember you have to look real hard..
It's possible that the paper may be running into a foreign object and not feeding in at all. A foreign object could also cause the paper to stall, or even feed-in crooked. Remove all the paper and use a flashlight to look carefully into the paper feed-in area. Look for a pen, pencil, push pin, paper clip, candy, etc. If you can't see anything, then actually pick your printer up and turn it so the paper opening is facing down and shake it a little, side to side. Your trying to dislodge anything that might be stuck in the paper entrance area. If nothing falls out, then turn it back over and use the flashlight to once again look inside that area. Sometimes you'll see an object that may have moved over into view while you were shaking the printer. Any foreign object might block the paper from actually being able to move forward, so then the printer thinks there is no paper installed. You may have to even remove the Top Cover to be able to get a better view of that paper feed area. Unfortunatly, just removing that cover is not always that easy, especially on the newer printers. You may need a Service Manual for reference, disassembly and troubleshooting. I have not checked, but you can normally find Service Manuals for most printers, at www.2manuals.com (most Service Manuals can usually be downloaded for around $10 +/- ). Even if there is not a foreign object stuck in that area, with the top cover off, you might just possibly see what the problem is and even be able to correct it..
Oct 17, 2007 | Lexmark X2350 All-In-One InkJet Printer
1,151 people viewed this question
k24674
