Question about RCA TH1101 MP3 Player
Write-Protection I downloaded a USB formatting tool because I couldn't right click to format the MP3 Player. However, when the disk begins to format it says "Device Media is Write-Protected". How would I remove this? Thanks
  • jedimunky Sep 22, 2008
    I fixed it myself. Does it still count as a Fixya?
  • 8,596 Answers
Yes.
Posted on Jan 09, 2009
Error windows was unable to complete the format
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
Feb 26, 2014 | SanDisk Sansa Fuze MP3 Player
Write protect error preventing format on centon 16 gb data usb hard drive
Look for a switch or button on the side of your MP3 player.
It might have a lock/unlock symbol on it, or read "HOLD."
This switch effectively disables the player so it doesn't turn on in your pocket when you don't want it to.
Move the switch to the "Unlocked" or "NO HOLD" position to remove write protection.
This position may also be labeled "R/W" for "read/write."
If you have no switch, continue to next Step.
Check with your manufacturer documentation and support.
Some players have options to securely lock them so data is not transferred or overwritten without permission.
Format the MP3 player.
This step should only be taken as a last resort because it will delete all files form your MP3 player.
To format, select "Control Panel," "Administrative Tools" and "Disk Management."
Select the MP3 player and click "Delete." Right-click on empty drive and select "New Partition." Follow the on-screen instructions to format.
hope this helps
Oct 29, 2012 | Centon RC16GBSDHC4 Secure Digital High...
I am having the samsung SVO411N pen drive it is not formattting and showing error of write protection so how to remove it? while formating it gives the error to remoe the protection from volume in...
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 07, 2010 | iLO (2 GB) MP3 Player
Sandisk 2 gb pen drive not doing format insert usb but show u want to format and yes so not working format option so pls given me some importent tips argent
Hello friend,
You can try the following format may this can help.
Try to format the mp3 player like this method:
Go through the : Setting>Control panel>
Administrative Tools>Computer Management>Disk management>
locate you mp3 player then
Try to format fat files system.
hope this help you
Regards
uttam
Jan 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My pen drive now showing write protected what i do ?
2. Format pen drive
Aug 29, 2009 | iLO (2 GB) MP3 Player
How to remove write protection from my pen drive
2. Format
Apr 07, 2009 | Pen Drive V-Stick 4GB MP3 Player
Uknown format
When using your MP3 player for the first time you should format it. Formatting prepares the disk (storage medium) for any reading or writing. It erases all information on the disk, and tests for any bad sectors or errors. Below are the steps for formatting your player: -Connect the disk storage (MP3 player) to your computers USB port. If the computer pops up a window asking what do you want windows to do? Click cancel. -Right click on My Computer and click on Explore. Look for the drive Removable Disk (E:) [The letter drive may vary depending on your computer] This is your MP3 player. -Right click on the drive Removable Disk (E:) and click Format… A small window will pop up displaying Format Removable Disk (E:) Click Start. Read the warning and click OK. Format is complete.This procedure can be done occasionally to erase all data on the disk storage.
http://www.nextar.com/frontend/support.asp?CATEGORY=10000309&MODEL=MA715&subpr=624950167&categ=519278318
Jan 21, 2008 | Nextar MA7151B MP3 Player
I download music on my MP3 player and it shows Empty Disk
i think you should format your mp3 player to Fat32!! that is the best solution, NTFS doesn't support both mp3 & mp4 players
Nov 18, 2007 | iLO (2 GB) MP3 Player
Two problems with my mp3 player
Hi Mina. An internal memory corruption might have occurred on your player, and would need to format your player through "Disk Management" (I'm assuming you have Windows XP or Vista). Here's how: (1) First, set your player to MSC mode by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MSC" (2) Open "Computer Management" by right-clicking on the "My Computer" icon, then selecting "Manage" (3) Your "Computer Management" window should be divided into 2 panes. On the left pane, click on "Disk Management" (4) On the upper right pane of "Disk Management", you should find the drive letter corresponding to your Sansa E250. The lower section also contains the drive # pertaining to your E250. Right-click on either drive letters pertaining to the E250 and select "Format". Follow the on-screen prompts. Make sure that the "Quick Format" checkbox remains un-checked. In general, Disk Management is more the effective tool for formatting your E250 and assuming the format processing completed without any errors, you may now use your player as you would. You may want to set the mode of your MP3 player back to "MTP" (if you're going to download subscription songs -- otherwise, just leave it in MSC mode) by navigating your menu as follows: Menu >> Settings >> USB Mode Choose "MTP" In case you get the error "Unable to Complete Format" or the format process is unable to complete, you may want to call the SanDisk Tech Support guys for more advanced troubleshooting (I call `em when I'm at my wit's end lol) I hope it works :)
Jun 02, 2007 | SanDisk Sansa e250 MP3 Player
RCA TH1101 MP3 Player Logo
381 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
