Question about Maytag Washing Machines
MAYTAG MFW9700 - GETTING FH ERROR CODE.. CAN WASH WITH COLD ONLY.. HOWEVER HOT OR WARM GETS ERROR CODE.
  • 958 Answers
SOURCE: Still getting FH codes
does you unit have this water sensor at the bottom part of the unit?... if so..sometimes they get too sensitive and dictates an error message.
you can experiment by dsconnecting this wire and if it does not change anything, then short the wires. i am not sure if this is a normally open switch or a normally close switch.
if you jumper a wire on the two wires and it indicated a different error code, then it is a normally open switch. remove the jumper wire and w'e'll continue trouble shoot your unit.
tnx for using fix ya.
drcool
Posted on Aug 19, 2008
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
abhishek33
  • 1239 Answers
SOURCE: Whirlpool 6th Sense AWM8123/1 error code FH
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Posted on Nov 28, 2008
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
SOURCE: Error FH Maytag front loader MR@9700sQ1
Your drain is clogged, not the one in the wall where the drain hose goes, but the internal drain, you have to use a 7mm quarter inch drive socket and a 2 inch or longer extension. There are three screws at the very bottom of the washer which must be removed. When standing you cannot see these screws, you have to lay down and look under the washer, between the feet of the washer to find them. Once the bottom cover is removed there is a "cylindrical box" thing with a front cover, the front covers is simply screwed into the cylindrical box housing, unscrew it. Warning, there is a lot of water in here so don't be sitting when you remove it. When you get it open you will discover that this is the internal filter, you'll find small socks and coins and god knows what else in here. Now follow the drain line out and feel it from the outside by pinching it to see if it is clear, if it is clear it should compress quite easily if it is clogged remove it and **** it out with a wire hanger. Reassembly is the opposite of disassembly. This should fix you error message. And buy the way if you remove the top cover there is a "Technicians Manual" stored inside the washer under the top cover that describes some of this procedure and defines all of the error codes.
Posted on Aug 03, 2009
How do i fix the FH error code on a kenmore elite he 3t washer?
This indicates a water problem. Make sure you have both hot and cold water turned on and running to the machine. If pressure is to low on either hot or cold you will also get this reading
Jun 23, 2014 | Kenmore 24032\24036 Top Load Washer
Maytag front load FH error msg
May be a water pressure sensor problem.
This tells it when the tub is full.
start with this video
https://www.youtube.com/watch?v=2pIVkAxWSXg
Nov 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
Timer display blinks fh on maytag epic front loader
First try turning off the machine for 30 minutes. Then check your inlet valve. Shut off valve, switch off machine & see if the water comes full flow. Check the filters on the machine inlet entry, they could be blocked, clean out.
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within 1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear for several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Inlet valves can be purchased thru the net and fitted by you easily.
Feb 25, 2013 | Maytag EPIC MFW9700S Front Load Washer
Washing maching flashes F H on time display
Hi
The FH code indicates a fill failure. The problem can be with the fill valves, flow meter or the pressure switch. This error occurs if the control doesn't see the flow meter turning. This usually a fault of the flow meter but be sure both the hot and cold water valves are working. Try a hot water wash cycle and confirm that hot water is coming into the washer. Check both valves and if they are working the problem is most likely the flow meter.
Also the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Please get back to us if you have further query else please accept the suggestion.
Mar 02, 2011 | Maytag MAH6700A Neptune High Efficiency...
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can't get anything but warm of hot water
If you set the washer for cold wash with a cold rinse, no hot or warm should enter the machine. If any hot or warm enters machine on cold / cold, check to see if the hot and cold hoses are hooked up correctly, and not reversed.
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag epic
hi there,
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
FH error
You are correct..
FH is an indication the the machine is not sensing enough water flowing into the machine....
The only thing you can do without taking the machine apart is to disconnect the water hoses to the back of your machine and inspect the filter screens for any type of debris that might be restricting water flow into the machine. Typically, the cold water line is more susceptible to foreign matter than the hot waterline.
If screens appear OK then the problem may be with the water fill valve, water flow sensor, (flowmeter) water pressure switch or blockage in the water pressure switch hose.
However.. if everything is fine using just cold, verify hot water for proper pressure or possible kinks in the hose.
Jun 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
272 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
