Question about HP OfficeJet 4215 All-In-One InkJet Printer
Will not print
This printer has a fax, scan and copy button, but not a print button which would be helpful considering that it thinks I am faxing but not printing.
how do you get it to print? I keep sending print jobs to it but it is not printing.
please help.
  • 2 more comments
  • Anonymous Sep 30, 2008
    The printer USB cable is presently disconnected. If I connect the computer to it, try to send a print job then my Spools.exe runs continuously at 99% effectively stopping every other function until I restart with printer unplugged.
  • burgos_myra Oct 14, 2008
    I have HP Officejet 4215xi printer I move it to my lab top and now it want
    print the lab top had never a printer on it before printer will not print a test
    page and will not print
  • Anonymous Nov 03, 2008
    I have the same problem please help
    i have the exact same problem please help
Try unplugging the USB cable from the back of the computer, not from the back off the printer. Also, try deleting the printer from/at the printer/fax page and restarting your computer so it will reinstall. In either case, when checking the printer/fax folder, make sure there is nothing pending printing. If there is, click on delete all pending printing jobs. If there is a print job pending and you can not cancell/delete this job, then you must delete the printer icon and restart your computer. Aloha!
Posted on Oct 07, 2008
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
HP 4300 officejet fax mode to print mode
Hello etilton
Are you trying to print from a pc or do a copy?
Button 11 Fax: Places the HP All-in-One in fax mode and presents the Fax Menu. Press Fax
repeatedly to scroll through the options in the Fax Menu.
Button 12 Scan: Places the HP All-in-One in scan mode and presents the Scan To menu for
selecting a scan destination.
Button 13 Copy: Places the HP All-in-One in copy mode and presents the Copy Menu.
Press Copy repeatedly to scroll through the options in the Copy Menu.
heres the rest of the manual pdf reader required
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
If this solution was any help at all please press accept or ask more questions with the other button.
And if you need anything else let me know, you can ask me 24/7 by clicking
on the ask me button, I will ansver in most cases within 24hours.
Thanks and good luck!
May 04, 2008 | Office Equipment & Supplies
I want to send a fax message to my friend, can I use my EPSON NX410 printer?
This model does NOT support faxing.
It is considered a 3 in 1 (Scan, Print, Copy) - NOT 4 in 1.
Apr 05, 2011 | Office Equipment & Supplies
How to print fax log
try this
* Press Setup menu (setup button) on the printer.
* Go to the second option print Report.
* Select the 6th option Fax log. Press Ok.
* The fax log will print now.
Apr 16, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Fax, Copy, Scan Buttons do not change
Sounds like switch inside operations panel has broken, there is no reset that will fix it, will need new operations panel.
the reset code on this machine is menu # 2 8 6 4 then maintence shows enter 99, the first bit must be done super quick.
Nov 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Samsung 3160fn
This is a multifunctional unit: it copies, prints, faxes and scans. There are three green buttons listed as "FAX", "COPY" and "SCAN". You need to press COPY if you want to make copies, since the default setting is FAX. The user's manual contained in the CD will show you how to change the default setting to COPY.
Sep 06, 2007 | Samsung CLX 3160fn All-In-One Printer
HP OfficeJet 4215 All-In-One InkJet Printer Logo
199 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
