Question about Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C)
I need to know how to install my Linksys Wireless-G Notebook Adapter v4
I have the drivers already. But now what do i do to connect the Adapter... Would i need some CD to install somethine else or what? plz help me..
This does not work for Windows XP because Setup.exe on the driver CD fails to run (quickly opens a black command window and disappears immediately and samething happens with autorun also). The Linksys WMP54G driver manual, as located in that install CD clearly says that for XP, we should install the PCI adapter at first, and then choose to specify the CD path during the XP's driver wizard. But even that did not not work. If anyone has any clues, please share your experiences. Thanks. -Satya
Posted on Nov 25, 2008
  • Linksys Master
  • 4,338 Answers
On the Linksys adapters you have to install the drivers first, then install the adapter.
First, un-install the drivers and power off the computer. Remove the adapter . then boot the computer . Reinstall the drivers and power off, re-install the adapter.when the computer boots up it will find the adapter.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 12, 2008
I already installed the right driver for my Wireless Adapter of my laptop but I cant connect to the internet through wireless connection. It say's their "The driver successfully installed used Fou
Did you reboot after install? What does it say when you try to connect? Why did you have to re-install the wireless adapter driver? Did you download the driver from Asus?
Jan 08, 2013 | ASUS Eee PC 1215BPU17BK 121Inch Netbook
Usb adaptor
you might be knowing about it... but check--
Yes you an can but the purpose of the Wireless Usb adapter is to get the wireless connection from the Router to the PC (Computer)
Connect the Wireless USB Adapter to the usb socket of the computer and install the Drivers with the Help of the CD.
Note to get the wireless connection you need the wireless router connect as well in home network
Jan 24, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Not connected showed on my laptop
Download the latest adapter driver for this adapter from the link below:
http://kb.netgear.com/app/products/family/a_id/1268
Install the adapter using thesr drivers and check if that helps.
Jun 21, 2009 | NetGear WG111 802.11g/b Wireless Adapter
No wireless adapter detected ad wireless button ot turning on
First u need to make sure ur adapter is installed correctly.
1. Click on Start-->Run-->Type in "devmgmt.msc"
which will open device manager.
Under device manager , u should find network adapters, make sure ur adapter is listed under it without any yellow exclamation mark or red cross which would mean that the drivers are not installed correctly or the adapter is disabled. In this case u need to reinstall the drivers via the CD.
2. Secondly u need to goto start-->run-->type in "msconfig"
which will open the system configuration window. Now under the "startup" TAB. Find the service for ur wireless card and disable it by unchecking it and then apply the settings and OK.
Reboot computer once
3. After reboot, goto start-->run-->type in "services.msc"
It will open the services windows . Find an option for wireless zero configuration . Rt click on it and start it.
4. Goto start-->run-->type in "ncpa.cpl"
It will open network connections window.
Rt click on Wireless network conection and enable it .
If it is already enabled , then rt click on it again and click on "View available wireless connections"
It will give u a list of all the wireless connections available in ur area.
Click on the one which is ur connection and then click on connect.
It might ask u for a wireless key if it is a secure connection. Enter the key and it should all work fine.
May 25, 2009 | Acer Aspire 5520-5579 Notebook
WPC54G wont install power light is on
The problem is that the PCI slot/socket where the wireless adapter is snapped/connected is not not compatible with the adapter. I suppose that the adapter is more more faster than than socket so it can hardly function as it should. I recommend that you return the adapter and get a slower version of the adapter. Make sure that the drivers are properly installed by removing/uninstalling any previous software from the system.
Apr 28, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Network adapter
if you have the driver cd means insert it and install the LAN component....it will show you the network adapter......
is this cleared your problem?
Apr 09, 2009 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
I want to install network adapter
hi! there,internet connection using your lan card or built lan adapter on *********** board if your network to public server e,g In your town telephone w/internet using usb port or broadband wire less no matter where,as long you subcribed there service ready for internet connection,i thing this kind of service once you purchsed and subcribed they are responsible to connect to your computer,but somehow this is your request,external land card when you buy it is already provided w/ cd driver installer and built land adapter on mother board driver was on mother board cd installer.if in the absence of installer you can down load to web site there free and there is you have to purchase take name of mother board you can see on inside pc and on *********** type this website just put .com at end.and select what ever you want.same with external lancard,insert your externai landcard on mother board on white slot.but you have to remove cover for land card back of cpu.check the driver of land card in device maneger.
to open device maneger ,control panel,system properties.connect your usb cable both on land card and modem,wait a minute until installation appear in your screen follow what wiazad
Apr 02, 2009 | Dell OptiPlex GX260 PC Desktop
Wifi connectivity problem
It's possible that the driver for your wireless adapter is already installed. Check under Device Manager > Network Adapters if there is anything pertaining to your wireless adapter. Make sure that your wireless adapter (under Device manager > Network adapters) does not have any red X or yellow question mark.
Red X indicated that it's disabled , while yellow question mark will suggest that you need to update the driver. If your wireless adapter is working properly under Device Manager > Network adapters then you will need to configure it's utility for wireless connection.
If you are running windows XP, look for the wireless icon in the lower right side of your task bar and use it to connect to your preferred network.
Good luck and have a nice day!
Sep 30, 2008 | Computers & Internet
Netgear 108 wireless usb adaptor
This is a driver problem, it may be windows generic driver that has installed; so if you have already installed the software, uninstall it and remove the adapter. Restart the pc, then insert the cd driver, but don't let it autorun, then re connect adapter and this time when it asks for the driver point windows to look on the cdrom for it instead of allowing the cd to run the installation.
Jul 12, 2007 | NetGear USB 2.0 108MBPS Adapter 802.11...
Open Questions:
Linksys WPC54G Wireless-G Notebook Adapter V2.0 (WPC54C) Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
