Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam dp01 fx cd.. OOPS!!! Please help.
I was about to do some recording and setting up the Tascam. Accidentally, I plugged in the portastudio with my laptop power supply cord.
Now, when I try to power the portastudio up with the correct cord, I dont get any power, and here a buzzing noise from the power adaptor.
I am sick! Can someone help me with this!
I need this portastudio!
Thanks,
Abe
    Scholar:
  • 70 Answers
Depending on the voltage that your laptop uses, if that voltage exceeds the Tascam required voltage you might have burned out the Tascam power board. Not good. I know you don't want to replace the entire unit. Try contacting Tascam directly they might give your an alternative in just replacing the power assembly.
Posted on Oct 13, 2008
Hello my name is Frank .I would like to know how to hookup mic with phantom power.Tascam dp01
Unless you have the FX model, there is no Phantom built in. You will need to get an external Phantom Power Supply, such as this one by Audio Technica http://www.zzounds.com/item--DAVAT8801
Feb 24, 2010 | Tascam DP01 All-In-One Recording Package...
Tascam DP01-FX/CD
i tell you connect to the computer your device
and right click on your device and format it i have the same prob now it fixed
Nov 25, 2007 | Tascam DP01FX All-In-One Recording Package...
DP-01FX/CD
Unfortunately it's pretty much impossible to get a recording to sound like anything produced commercially these days without using lots of compression. Your burned CD problems might be the result of a faulty burner on your DP01-FX/CD. I have a 2488 and I still export all my mastered songs as wav files and burn them onto disc using my PC just because of the flexibility on the PC and you can control settings better which can cause disc burning problems (not to mention that the burner is newer and faster on my PC).
If you don't want to work on a PC you could look into replacing the burner in your Tascam. It is similar to replacing a PC's burner and the either the Tascam site and/or the Tascam Forum should be able to provide you with the specs and a list of compatible CD burners.
To get the final product to sound louder you could invest in an external compressor (a good used one should run you less than $100). You'll have to use the DP01's send loops to route a bounce of the stereo mix out to the compressor and then route the result back into the DP01 inputs and record on a couple of free tracks.
Hope this helps.
Cheers
bd.
Oct 14, 2008 | Tascam DP01 All-In-One Recording Package...
DP-01FX/CD Problem
nslo, tell him to try replacing the power supply first, power supplys burn up ALL the time, as long as the plug fits and it has a rating of equal or greater amperage, same voltage, equal to or greater watts then it will work. Those variable voltage multi plug ones they sell at k-mart work but I've never had one that lasted long.
Jul 09, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Portastudio DP-1FX/CD When I turn it on I get this message. Err: 12 Please PWR OFF
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
Apr 22, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD
Check to find out the size of the active FAT partition. You may have a 'less than optimum' amount of memory left in that partition. Switch to another partition and see if you can record in that one.
Dec 04, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP-01 FX/CD Digital Portastudio
Here's a link to a forum where someone else encountered the same error. Seems it was due to running out of disc space in that instance.
http://www.tascamforums.com/lofiversion/index.php/t10089.html
Tascam DP01 All-In-One Recording Package Microphone Logo
181 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
