Question about Maxtor Hard Drive
External HD problem
I recently bought a Maxtor 3.5" Basics - 500GB 3.5 inch External Hard Drive, every time I power up my system and try to access the drive it tells me it needs to be formatted, I bought the new drive to save my files music etc but anything I save to the drive is inaccessable after my system has been turned off as it tells me the drive needs formatting, also it is only showing up as a 36GB drive not 500GB
  • Anonymous Sep 26, 2008
    XP only intially recognised 500GB Maxtor Basics External HD as 50GB but loaded files without problem which could be reaccessed without problem. After HD shut down and restarted some days later all attempts to access HD resulted in a request to format the disc. Attempts to format were rejected by Windows XP BJAD
  • dgilliland Oct 01, 2008
    I have the same problem. first time I used it the drive seemed to work ok, the next time I turned on the PC it told me to format the drive. XP cannot format the drive and now it won't work. Help
SOURCE: Maxtor Basics external portable hard drive not getting detected has the answer for this
Posted on Aug 10, 2008
SOURCE: power supply for Maxtoe Basics External Hard Drive 500GB
Is 12VDC 2,0A the inner pin is + and the outer pin is -
Posted on Dec 04, 2008
  • 416 Answers
SOURCE: maxtor basics desktop storage 1000gb wont start up but has power
Best is to take it to the shop you bought it from. they will replace it. ask them to transfer the data to the new one. the chances are they might do it.
Posted on Jan 15, 2009
SOURCE: open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
Posted on Mar 29, 2009
  • 1884 Answers
SOURCE: Restore factory settings on maxtor basics external storage 1000gb
What do you mean by factory settings. From the factory, the drive came just formatted with no data on it. If you want that then format the drive in WIndows. My Computer->Select the drive that is Maxtor, right click it and in the box that opens format is one of the options. Select and follow instructions.
Posted on Nov 16, 2009
I dropped (about 9 inches) my Maxtor 500Gb external HD
Hi John, yes you are right. Your hard-disk is damaged due to the fall. And although your computer won't find it you may still be able to recover some information from the drive.
If running Windows, plug-in your drive and check the taskbar to see if the safely remove icon comes up. if it does then try one of the following:
1. Install and use a good partition recovery software to recover your entire partition to a safe location. I personally use EASEUS partition recovery.
2. Use a file recovery software like R-Studio to try and recover individual files
Note that either of these processes will take a while, so be patient and make sure you have lots of free space on your computer or on another external drive.
I hope this helps, all the best
Dec 01, 2013 | Maxtor Computers & Internet
I dropped a short distance my maxtor 500Gb external HD
Open it up, and gently move the pickup arm, see if it got knocked out of place. When it is free, close it up and try again. If it is under warranty, send it back first.
Maxtor 3200 hard drive not working alongside Maxtor Basics
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 21, 2009 | Maxtor Hard Drive
I am trying to install a Maxtor Basics 500GB External Desktop Hard Drive and cannot see the drive on my PC. I'm assuming it is not installed. I operate a Windowss XP Platform. Help!
Right click on my computer and go to manage, then go to storage, disk manager and see if the disk shows up there, you may need to partition it first, you can make one partition of that hard drive. If it is not in there, check the jumpers and make sure it is not the same as the main HD. The main drive should be master and the second drive should be slave, or make it cable select and do it in the bios.
Jun 21, 2009 | Maxtor MaXLine Pro 500 500GB 7200rpm...
Open external drive maxtor basic 500GB
Mar 28, 2009 | Computers & Internet
Maxtor Onetouch 500GB went dead
if there is warranty take it back to the shop you bought it from.
Dec 31, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Maxtor basics 500gb PN-9NZ2A4-500 will not power up. cannot access data on the drive
Have you tested to connect your HD with another cable (power cable)?
Is it an internal drive or external drive?
The following link is useful to do some tests with DiscWizard.
Aug 20, 2008 | Computers & Internet
Delete info from an external hard drive?
run diskmgmt.msc delete. then create then format .. also theres a tool called Wipedisk from
Jul 21, 2008 | Maxtor Hard Drive
Maxtor Hard Drive Logo
120 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
