Question about Sanyo PLV 70 Multimedia Projector
Sanyo PLV 70 - Power Won't Turn On
I've plugged the unit in but it doesn't turn on! It's happened the last few times I've unplugged then plugged it back in. Prior to today, i've messed around with it, opened the projector up, and eventually I plug it and and the lights come on, however, I've had no luck in my latest efforts!! I've tried putting a new lamp in it and it still doesn't work. I've tried differenct outlets, and still no luck!! Anyone come across this problem???
It could that the plastic stem on the inside of the lamp cover on the underside of the projector may have snapped off. if it has you'll have to wedge something onto the cross shaped hole, to keep button inside the hole pressed in, in order for the projector to turn on
Posted on Nov 15, 2008
Theatre projector is unable to switch inputs in menu
This is worth a try: Turn everything OFF. Unplug all the inputs from the projector and turn them off too. Next, turn the projector ON and all the input devices ON. Then, one by one plug each input device (already turned ON) into the projector. See if this helps. I have a SONY monitor that supports multiple inputs and a few times this has worked.
Good luck.
Jan 28, 2015 | Sanyo PLV-WF20 LCD Projector
I cannot power up my Sanyo PLV-70 projector. I have changed the power cable but the box is still dead, no sign of any power input.
try another wall outlet if that dosent work try a nother cord, than if it still wont respond it could be a blowed fuse or a bad power bord.
Jun 04, 2011 | Sanyo PLV 70 Multimedia Projector
Whole projector (HD Pro Wide mutliview Model # PLV-70) shuts down after 10 minutes or so of use. Lamp is perfect.What do I do to fix this? . Happens nearly every time. Is there some control button I shoud...
overheating. clean out the projector with canned air. dust keeps in the heat. should be done periodically. about every 500 hours or so, depending on usage and environment. if it happens often after that, replace the thermosensor and check the fans.
Oct 20, 2009 | Sanyo PLC XU35 Multimedia Projector
SANYO PLV-70 - powers up for approx 5 secounds and then turns of
we had this problem and it ended up being that one of the fans under the lens assembly was not working, causing the system to shut down when it tested it at startup
Dec 11, 2008 | Sanyo PLV 70 Multimedia Projector
Loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo Television PLV-55WHD1
i heard same popping sound and my power button flashed red and will not turn back on.?
Sep 15, 2008 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Sanyo PLV 70 Multimedia Projector Logo
360 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
