Question about Dell Spacesaver USB Keyboard J4624 SK-8115 RT7D50
No volume i hit a button on my keyboard and now i have no volume
  • 21 Answers
Pls select control panel in ur computer and select sound and audio device......in the first tab u can se one tab called volume tab in tht u can see one tab called advanced pls click tht thn u can see one window callled volume control will araise ...pls check wheter thr any tick in mute if it is pls delete the tick mark by clickin tht box again thn u can gain ur volume back.....
Posted on Sep 21, 2008
Volume buttons on my toshiba laptop is not working
There are other ways to adjust the volume.
Right click on the megaphone located at the bottom right near the time. You can adjust the volume there.
Look on your keyboard and normally you can Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys with the megaphone that adjusts the volume (1 key increases the volume, 1 key decreases the volume and 1 key mutes the volume).
You can adjust the volume in the Control Panel's audio or sound properties. Click Start/Control Panel and look for Sound or Audio.
May 04, 2012 | Computers & Internet
My Panasonic cf-w8 is mute? How do I unmute it? Does the Fn button have something to do with it?
Well the FN key could have set the mute on if the mute key was also pressed.
Click the megaphone at the bottom right near the time and open the audio properties and volume control. Check to make sure the mute is not checked.
You can also click Start/Control Panel and look for Audio or Sound and adjust to make sure the mute is not check.
On your keyboard if you Press and Hold the FN function key at the lower left portion of the keyboard then you can hit the key that has the megaphone with an X across it to take the mute off.
Some laptops have 3 buttons that control the volume. One for turning the volume up, one for turning the volume down and one for muting the volume.
May 02, 2012 | Panasonic Toughbook W8 Rugged Notebook -...
Volume balance not working
There are different ways to adjust the volume. Maybe you have the volume on mute. There are keys that control the volume on some laptops. Normally you would Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys (keys with a megaphone on it) that control the volume.
Some models might have buttons you can press that control the volume.
You can always click on the megaphone at the bottom right near the time and adjust the volume properties.
You can click Start/Control Panel and look for Audio or Sound and adjust the volume.
May 01, 2012 | IBM Computers & Internet
Solton ms60 keyboard... volume stuck , can't adjust sound once set
There are a number of ways to adjust the volume. 1) Normally a button or keys on the keyboard will adjust the sound volume. You might have to press and hold the FN key or the Alt key then hit the key that adjusts the volume up or down. 2) If you right click on the megaphone at the bottom right near the time you can adjust the volume. If you click Start/Control Panel and look for Sound and Audio Devices you can adjust it there. 4) If you click Start/Programs/Accessories/Entertainment you will see a way to adjust the volume.
Apr 02, 2012 | Computers & Internet
Pc sound is not working right now hepl me
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 20, 2011 | Computers & Internet
Microsoft Wireless Keyboard 1000 v 1.0 volume keys not working
On 32-bit machines: Use the windows search feature to find "hidserv.dll." Once located, copy the file and paste it into the %systemroot%\system32\ directory. Open the "Run" dialog box by keying the windows + R. Type "services.msc" and hit enter. Locate the HID Input Service. Right click and click "start." This should solve the issue!!
Apr 08, 2009 | Computers & Internet
I have a thinkpad t43 low volume
FYI the volume control on the keyboard takes precedence over windows controls. It doesn't use the windows sound mixer but uses its own program. Try to hit the mute button and see if that gives you sound, if not try turning the sound all the way up using the button and then all of the way down and then all of the way back up. Doing this sometime fixes that issue with Thinkpads. And if it still doesn't work hit the mute button again.
Jan 28, 2009 | IBM ThinkPad T43 Notebook
No sound (ringer, keyboard, etc.)
You may have hit the mute button, you may have turned the volume down using the buttons or you may have accidentally put it in airplane mode or another mode where "sound off" is specified.
Hit the volume mute button, hit the volume up button, go to settings for the volume option, go to the settings menu and change the mode that the phone is set to a standard mode
Dec 18, 2008 | Cell Phones
Computers & Internet Logo
125 people viewed this question
Alun Cox
