Question about Electrolux EL5020 Vacuum
Change cord on electrolux EL5020
The electric cord is disconnected inside. How do I open the unit to get to the cord? How many screws are there? I am ready to give up the cord recoil.
My email: avilynn@ctc.net
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Posted on Oct 17, 2008
How do I replace the power cord on an electrolux 8502A vacuum cleaner?
1 Unplug the vacuum and remove all accessories such as extensions and brushes. Open the vacuum's outer casing to get at the end of the power cord. Exactly how you will do this depends on the model of vacuum. Generally it simply involves the removal of two to three Phillips-head screws.
2 Follow the power cord to the two connections at the vacuum's motor. Unfasten any clips or holding bracket and disconnect the cord from the motor. Sometimes this can be accomplished by unscrewing two connection screws, other times the cord is soldered directly to the motor. If this is the case use wire cutters and cut the cord about 4 inches from the motor to give room for splicing on a new cord.
3 Insert the new power cord into the vacuum. Follow the exact same path as the old one. If there were any brackets or clips that held the old cord in place inside the vacuum or out use them on the new cord.
4 Tie a knot in the cord on the inside of the vacuum casing so that it will not accidentally be pulled out of the motor once it is in use.
5 Connect the new cord to the motor in the same fashion as the old one. With wire strippers take off about 1 inch of insulation from the new cord to expose the two wires. Either wrap them around the connection posts and re-screw, or twist the new cord wires around the 4-inch remnants of the old cord and seal all exposed wire and connections with electrical tape.
6 Replace the vacuum's casing in reverse order from how you removed it. Plug in the vacuum to test.
Sep 11, 2011 | Vacuums
My power cord will not retract back into the housing< i would like to open the back of the unit but there no screws or bults to due so. How do you open the back of model c151d
Try standing vacuum on end, then gently tugging and releasing cord. This generally will retract it.
There are many problems that can result in disassembly and reassembly by an untrained person, including shock and fire. For those and other reasons, I don't recommend trying this yourself. Take it to the nearest Aerus Electrolux store for repair.
The back of the vacuum can only be removed by separating the top and bottom portions of the canister. The cord winder will need to be removed and the wires all disconnected. The cordwinder is then taken apart and the cord rewound and set for proper tension for rewinding. If the cord is simply stuck due to having been pulled out too far, this is generally not necessary.
http://www.aerushome.com/storelocator/
Jan 07, 2011 | Electrolux UltraLux 2000 Bagged Canister...
HOW TO REPLACE CORD BROKE INSIDE UNIT CAT TAKE IT
you know the cord is broke? and you wish to remove and replace the broken one? well it has to be opened to remove or reconnect the broken wiring. is there screws attaching the removable parts in order to get to the broken cord? recommend you locate broken wires and reconnect each wire to its color either white and black. and use electrical tape to cover each wire reconnected.
Mar 12, 2010 | Hoover Elite U5061-900 Bagged Upright...
1 ) how do you open the body of the vacum ? 2) How to replace the power cord? Epic 6500 sr
Very Carefully! LOL! Disconnect the hose from the door. Open the door. Remove the bag. Flip the vacuum on its top. You will then need to remove the trim pieces from the sides by sliding them toward the front of the machine(bag opening). Usually they won't want to go easily. The way I used to do it was by wedging a screw driver between the rear cover and the trim piece then gently tapped the side of the screw driver blade toward the front. Once you get enough hanging over you can grab and pull them the rest of the way. The vacuum should separate once the trim has been removed. ****I have to warn you. If you have never done this before it is extremely important to take note of how and where everything goes on an Electrolux. They are complex machines that are assembled in a fairly meticulous way.**** The best way for someone that has not had any training to replace the cord is by replacing the cord winder assembly that comes with a new cord. Otherwise you have to disassemble the cord winder. Not fun.
Dec 28, 2009 | Electrolux Epic 6500 Vacuum
Does anyone know how to get the bottom off the electrolux Epic 3500 SR I need to check the beater brush? Thanks Jim
Actually the top comes off from the bottom base. Remove the underside screws, flip the machine over and gently remove the gray cover from the motor and brush assembly. Once inside, remove two more screws holding down the brush cover which is also part of the tunnel. It will reveal the brush, belt, and much dirt so be prepared.
Dec 06, 2009 | Electrolux Epic 3500 Vacuum
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
Oct 04, 2009 | Electrolux UltraLux 2000 Bagged Canister...
No power
use a t6, or t4 screwdriver,
b4 u go on plz check the fuse of ur machine, or the power rating of it.
or check for the earthing.
Jul 16, 2009 | Electrolux EL5020 Vacuum
Electrolux EL5020A VacuumCleaner - taking apart
these[ things] you talk about are called lock clips.with a little force and a small screwdriver they open be careful not to snap them, take your time as you move along; the lock clips will start to reveal themselves more openly again take your time ,after the casing is opened it should reveal the electrical cord.;before you start this procedure make sure the electrical cord is unpluged from the power supply hope this helps you.adrian
Feb 16, 2009 | Electrolux EL5020 Vacuum
Brushes not turning Electrolux Intensity (EL5020)
it needs a new brush they get stripped out by hair and stuff
Nov 20, 2008 | Electrolux EL5020 Vacuum
Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Jun 06, 2007 | Electrolux Lux 7000 Bagged Canister Vacuum
Electrolux EL5020 Vacuum Logo
470 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
