Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Where to locate the lamp assembly
Behind the front bottom panel. It is removed by the two hand screws located behind the panel on the back side of the TV. ....Can you be more specific please?? I litterally open the whole backside of the TV and did not locate the lamp...this is very frustrating.
Look at the TV from the front, on the stand just under the TV there is a panel. Reach around the ends of the panel and you will feel the fasteners that hold the panel on. Unscrew the fasteners and the front panel comes off and you will see the lamp in the front center.
Posted on Oct 04, 2008
F22
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly.
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I had an F01 code and ended up replacing the CCU Board (part # w10205849) successfully and had 1 perfect wash. But the 2nd wash didnt complete. I replaced the CCU Board a second time and it's...
Hi
If you have already replaced your CCU you need to replace the door lock mechanism. Also you're still experiencing problems, you need to re-verify your electrical connections and check the CCU.
Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
The doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 25, 2011 | Kenmore HE2 Plus Front Load Washer
My Whirlpool front load washer has a cleaning cycle. When I try to clean it, it says F 22 on the time left display. What does this mean???
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
1. Unplug washer.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
(courtesy JSRock)
Thanks for using FixYa
Dec 22, 2010 | Washing Machines
What is F22 error?
This advice is for Kenmore Elite and Whirlpool Duet Front Loading washing machines displaying the "F22" error code.
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step introubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Unplug washer.
Sep 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code flashed f22 and the door is locked and will not open
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 25, 2010 | Whirlpool GHW9100L Front Load Washer
How remove the Sony Rear Projection TV KDS-R50XBR1
the lamp is located if you are standing in front of the tv, on thr right hand side behind the screen on the side of the tv there is a thumb screw that you have to remove with a flat head screwdriver then you can remove the door and see the lamp inside.
Oct 06, 2009 | Sony KDSR50XBR1 50" Projection HDTV
KENMORE HE3T F22
1. Unplug washer.
Jul 10, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Wfw9200sq had a F22 error, now the washer wont start any cycle
1. Unplug washer.
Mar 07, 2009 | Washing Machines
Need to replace door gasket
Remove the top cover by removing the 2 screws in the back.
Remove the dispenser drawer completely.
Remove the 2 screws on front of the panel where the dispenser drawer was removed.
Remove the screw on the right side behind the front panel.
Disconnect the wire harness behind the panel.
Starting on the dispenser side with your finger, pry forward the top of the control panel until it unsnaps.  Continue this all the way to the right and remove the control panel.
Go to the bottom filter door and remove the door.  Unscrew the one screw below the filter cap.  Remove the plastic insert covering around the filter cap.
Locate a small screw at the very bottom of the frame just below the filter cap and remove.  Sometimes there may be 2 but usually there is only one.
Open the door and locate the spring clamp usually located at the bottom of the door seal.  Remove the spring clamp.  This will loosen the front of the door gasket for removal from the frame.
On the right of the door gasket is the door latch assembly.  Unscrew the 2 screws and set the latch hanging by the wire harness.
Remove the 4 or 5 top screws holding the front panel assembly.  Once they are removed, the front panel will lift up and out.
NOTE!!!  THIS JOB REQUIRES 2 SPECIAL TOOLS FROM LG TO REMOVE THE SPRING CLAMPS ESPECIALLY THE REAR CLAMP.  THE SPRINGS ARE SET VERY TIGHT SO IT IS NOT EASY TO REASSEMBLY WITHOUT THE SPECIAL TOOLS.
Sep 23, 2008 | LG WM1814CW Front Load Washer
Sony kdf-55wf655
Jun 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
57 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
