I can't not connect my d-link on the net. my computer said that my card is active but i can't connect to the net
  • 781 Answers
You're question is lacking a few details
I'm guessing you have a laptop that has a wireless internet card and you're trying to access internet using a router in your home?? is that right??.. please post details of your setup!
Posted on Sep 20, 2008
How to install sim card in Lenovo s10-3? can I connect net through sim card?
Hello there
I have found the manual for your computer which says that removing the battery will enable you to get at the SIM card slot "on selected models". Obviously not all models of this computer will take a SIM card. I give below a link which will take you to the pdf format of the manual which you will be able to save to your computer for future reference.
http://download.lenovo.com/UserFiles/UserGuide/en/User's%20guides%20and%20manuals/S10-3/Lenovo%20IdeaPad%20S10-3%20UserGuide%20V1.0%20English.pdf
With regard to connecting to the net through the SIM card, this will depend on the type of SIM card and the SIM card service provider, but you should be able to if these are correct and you are in an area where mobile broadband is available.
Cheers
Oct 20, 2014 | Computers & Internet
I purchased 2 unlimited net10 phone cards got activation recepits when I called net 10 they told me that my cards were not activated and faxed all recepts and back of cards to net 10 but they said th
That is a reliability issue and reportable to consumer protection agency. Try speaking to net 10 at higher level an do let them know what you may do- only if they are not co-operative. They can help easily since you have not used the card.
Nov 15, 2013 | Cell Phones
I reformatted my pc but i dont have any sound card driver,when i click the volume control it says that there's no active mixer devices installed..how can i get the driver?can i get it thru net?
yes, you can downlaod it through the internet. i can also find the link for you, however i need some information.
*do you have a sound card or is it built into the motherboard (if its built in, the speaker ports will be next to usb plugs and ethernet connections... if you have a sound card, then it will be on an expansion slot, located below the motherboard i/o)
*what is the brand of the motherboard or sound card. if you dont know, just tell me the make and model of the computer
Jun 07, 2011 | Computers & Internet
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
How to check whether its working or not working?
If your PC LAN Card is active just connect the switch with Straight cable - & --you will see one yellow box in ritht side corner down to monitor screen...where the time appears.....also you can check in the Network Connections Folder. Or Right Click My Network Places> Properties> You will see local area Network....> Connected...then it is working if disconnected it's not working....Good Luck
Jul 29, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
HOW TO CONNECT IT TI A COMPUTER?
When the computers are powered up and connected to the D-Link hub,
the computers that are connected to the hub will light up the various LEDs on the hub to indicate which port on the hub is active. Also that computer's network card Link LED light should be on to indicate it is connected to the hub.
If the hub's LED is off and the corresponding computer's network card Link LED is off then the network cable is faulty, or the network card is faulty (or the network card driver needs installing) or the port on the hub and/or hub is faulty.
To determine which item is faulty, swap network cables around, swap computers to different ports on the hub etc
Cannot activate my sound card
You have to install the driver of your sound card. If it is no with you , you can download it from the net by giving the model of your sound card.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 03, 2009 | Computers & Internet
DWL 520 D Link Wireless PCI
disable the firewall and check the configuration of the ap
Dec 02, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
Cable connectivity
hi pat seems your router is not configure yet for internet connection, for cable connection you must log into the setup page of the router and clone the mac address of your computer.
to do that you can call 1-877-453-5465
to have someone walk you trough the steps.
flashing lights simply means activity on your network, and you get activity when you have internet connection.
hope that helps pat.
Oct 06, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless internet
Hello Sir,
This will depend upor ur mobile and operator service also. First activate GPRS in your mobile and go Connection (u can do manually) registered ur user id and password of ur internet connection. It can be activate in one or two minutes. And then u placed mobile at nearby computer and browse the net at computer. enjoy
Good Luck
"Don't forget to rate the solution"
Jan 11, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
