Question about Kenmore Elite 20972
Kenmore elite dryer model #110.63952102 start button wont stay on everything else works
Start button wont stay on
  • 1 more comment
  • guitflam Oct 28, 2008
    I have the same problem. If I hold the switch down it still functions normally. Found a solution?
  • Anonymous Dec 29, 2008
    I have the same probelm
  • boomop135r Mar 15, 2009
    I had to hold down my button for a bit to get it to work. Now it will not even start. Just clicks!
  • 30 Answers
I have the same problem with my Kenmore Elite dryer (model#110.74992300), and I replaced both the motor and heater relay and the problem solved. You can get the relay from www.mouser.com for $3 each. The model for the relay is T9AP1D52-48. You may want to open up the dryer to verify the relay model, it is printed on the relay.
Posted on Jan 02, 2009
Dryer won't stay on without the button held in
Most likely the motor relay or the even heat board is bad.
Oct 06, 2017 | Kenmore 74992 Gas Dryer
Our dryer doesn't stay on when you hit the start button. It turns off when you release the button.
The seal in ccircuit for run usually goes through a switch in the motor, whitch if it sticks or the switch goes bad, it wont stay running.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore elite dryer that wont stay on and wont heat...I push the button it runs let go it stops and it doesnt heat up even after holding the button down
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 19, 2011 | Kenmore Dryers
I have a kenmore elite gas dryer model # 70992990 <And when i push the start button and let off it wont stay running! Can you help?
heatman101
Sep 16, 2010 | Kenmore Dryers
My kenmore elite he4 dryer wont start
kenore elite oasis dryer won't start, when start button is held down it flashes F, book says call service center
Jun 30, 2009 | Kenmore Dryers
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
Nov 25, 2007 | Kenmore 63942 Dryer
Washing Machines Logo
708 people viewed this question
Sal De
fordexpert
Robert Rankin
