Question about Makita 18V 1/2"CRDLS Drill Kit
Makita BDF452 18v
Have two hi speeds forward two low speeds reverse
  • David Ford
    David Ford May 11, 2010
    What is the question or problem? Please advise and I will see what I can do.
  • 3 Answers
Get gear box checked common fault on this model
Posted on Jan 31, 2010
No reverse in john deere ''gator''
check to see if both wheels are spinning in forward, if not you have a bad motor
Oct 28, 2012 | Peg Perego John Deere Turf Tractor
Just bought a Jeep Hurricane Power Wheels for my daughter. I thought it was kind of funny that when the shiter was i the down position the vehicle went forward and when the shifter was in the forward...
thats exactly whats wrong with it,, reverse the wires on the switch itself that controls the direction and you should resolve your problem
Aug 02, 2010 | Toys
How to change drill chuck for makita hp 2040
if its a reversible drill there will be a screw in the bottom of the chuck, open the jaws as far as they will go and you should see a screw head, it is a left hand thread so put the drill in low speed selector this will stop chuck turning as easily, then turn screw clockwise as your looking at the chuck, when its out put an allen key in and tighten up the chuck hit with hammer now in a anti clockwise direction it should unscrew. repeat in the reverse procedure to fit new chuck....
Jul 31, 2010 | Makita & 1/2 Inch Drill
Hi I have a 95 75H.P mercury motor that makes a noise almost like the gears are skipping when i put it into reverse. Now forward works awesome. when in reverse at low speed the reverse seems to work a...
The reverse cable needs adjusted on the motor. What happens is that when you pull towards reverse, the cable doesn't move the shifter lever until the end of adjustment. This causes it to only partially engage. Hope this helps...
Mar 26, 2010 | Boating
No high speed on my TCV 6V ride on car
Try to check the forward terminal connection high speed going to batterry, possible of loose connection.
Dec 15, 2008 | National Kids Mini Cooper Racer Ride On...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
C 6 transmission
Forward drive in the C6 requires both the forward clutch AND the low/reverse, one-way clutch, or intermedaite band to engage. Since you have reverse but no forward, the forward clutch is most likely the problem, since it is needed only for forward speeds and does not affect reverse. Sounds like a trans rebuild.
Jul 14, 2008 | 1988 Ford F 250
Makita 18V 1/2"CRDLS Drill Kit Logo
152 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
