Question about Dual XDVD8182 Car DVD Player
Disc does not load keeps ejecting disc
Disc will not fully load
  • 1 more comment
  • eltzholtz1 Sep 20, 2008
    It started doing this new out of the box.
  • jgwis Oct 06, 2008
    Purchased the xDVD8182 about a year ago. Unable to load any type of disc. I contacted DUAL's number off their website and reached a 3rd party customer service center. The representative I spoke to told me I would need to the unit to one of their service centers and it would take a minimum of 4 weeks. DUAL's website has no other contact numbers or addresses. When I asked for a contact number for a DUAL representative, I was told they would refer me back to the 3rd party customer service center. It is safe to say I will not be purchasing DUAL products in the future... with this type of terrible customer service.
  • NPETREL1 Nov 17, 2008
    I HAVE THE SAME PROBLEM. DO I HAVE TO TAKE THE UNIT APART TO CLEAN IT?
  • 550 Answers
Clean the player
the track that the loader runs on is dirty, hists the dirt and reverses to prevent damage
Posted on Sep 20, 2008
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Why does my hhr radio try to load and eject a cd disc when there isn't one inserted
There is an arm in/on the left side of the disc player. Most likely the spring inside it is broken. Leaving the arm in the pushed back position. Some times kids put coins in there also. This will cause things to happen, to include killing the radio and/or cd player.
Aug 14, 2014 | 2009 Chevrolet HHR
Toshiba dvr19dtkb keeps showing "disc error"
You need to have the cd/dvd drive replaced.
Sep 02, 2012 | Toshiba Computers & Internet
Disc keeps getting rejected
see the cause and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
see the block d. attached.
Jul 20, 2012 | Televison & Video
My hp laptop keeps ejecting disc itself when i insert any disc. Wat do i do pls
> keep ejecting
The disk-drive is having a mechanical problem, i.e., it is not fully-loading the disk,
or it is not detecting that the disk is fully-loaded. Therefore, it assumes that the open/close
mechanism is "jammed", and so it ejects, to indicate that the disk-loading was not completed.
Replace the disk-drive.
Jun 26, 2011 | HP Computers & Internet
Hi, my Philips DVP5100 keeps ejecting DVDs. When loading a disc, it reads it for a short time showing LOAD. Then it ejects disc. Does it mean laser is gone?
It sounds like the drawer assembly may be out of alignment...may be caused by shoving the door in instead of pressing the button to load the dvd....the timing of the drawer and the laser assembly is critical to the proper operation on most dvd's...another possibility is that if the unit has a belt drive for the door load components, the belt may be slipping enough to cause it to not fully load...It makes the player think that you never put a disk in it so it will keep ejecting because it never received a "full load" signal from the drawer components. You can take the cover off and watch the operation of this to see if it is loading all the way..if not then you will either need to have repaired or try to obtain the service literature yourself to re-align the gears to make it load properly
Jan 01, 2011 | Philips Televison & Video
Hyundai CD player displays ''error'' for all functions
my cd player in my sonata keep eject the cd can anybody help
SOS
Dec 11, 2009 | Car Audio & Video
Wii keeps ejecting all games. Have had it for 2 years. Kids played on it all last week. Now it won't accept any game - it just keeps spitting them out.
There's either something jammed inside of the Wii's DVD Drive, or a part on the inside of the DVD drive is broken. All drives have a sensor on the inside to let it know that a disc is fully loaded and seated. If the sensor isn't engaged within a few seconds, it will spit the disc back out.
You can find a new DVD drive at the following website:
http://store.richspsxparts.com/wiiredvddr.html
Nov 19, 2009 | Nintendo Wii Console
The Wii keeps ejecting the disc and we can't play on it
With the Wii Console vertical, the discs should be loaded with the shiny side to the left. If you are loading like this and all discs are being ejected, then you very probably have a problem with the Wii Console.
To ck into repair go here:
http://www.fixya.com/ThreadView.aspx?thid=2204194&prdid=618512
May 12, 2009 | Nintendo Wii Console
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Dual XDVD8182 Car DVD Player Logo
336 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
