The EOS cameras have some sort of sensor built in to tell the camera which way the shot should be orientated on screen and when they are transferred to the computer. It sounds like the sensor is jammed or broken and sensing (for some reason) that the camera is upside down when the shot is taken. If you don't want to pay to have it repaired you can use a program to rotate them or turn of the image rotate option in the menu. I believe this ignores the sensor information.
You declined to specify the make and model of your camera, so I can't be absolutely certain, but on most cameras you start the self-timer by pressing the shutter release button. If this doesn't do it, please feel free to reply to this post, but be sure sure to specify the make and model of your camera.
My HDC-570AB Hitachi digital camera drains AAA batteries as soon as I switch it on so that batteries are running low within 2 minutes of taking pictures. It renders the camera useless unless I take out an endless supply of AAA batteries! Is there a solution to this?
Check to make sure that you did not accidentally change image format from jpg to crw(camera raw). Your camera lcd will only display jpg files and you need special software to view raw files on the pc.
If you haven't replaced the lamp, it is almost certainly time to change it. A weak lamp will cause the TV to play for a short time. As the old weak lamp heats up, it draws more current, and the reflector in the lamp, having become cloudy over time, converts the light into more heat rather than reflected it out into the set. Eventually the lamp draws too much current and the set turns it off, going into a restart cycle. Buy an original Sony lamp, as the aftermarket replacement lamps are known trouble makers. Be sure to rate this solution. Thanks!
i have the same exact problem with mine. it's two and a half years old as well. i also noticed that if you try taking pictures in any of the best shot modes the pictures come out looking like paintings.
My copy of Photo Viewer came on the provided disk. Run set up to load it (if you do not have a disk go to the key ring manufacturers website). When you use Photo Viewer make sure that your key ring is attached to a USB port prior to starting the programme otherwise it will not load.
Set everyone in an even composition, close together, maybe some standing, some sitting, whatever strikes you as a good picture.
Put the camera on a tripod or other tall article
Press the Mountain/Macro/Timer button until the (clock/timer) icon is displayed on the viewer. The button to press is just above the MF (Manual Focus letters)
Press the shutter button all the way down to activate the timer.
Press once for ten-second delay
Press twice for three-second delay
Press a third time to stop the timer
Jump into the shot! =)
The lamp next to the lens will start to blink and continue until one second before the picture is taken. The lamp will then stay solid during the last second to warn about the picture being taken.
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says.
"You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
